Replacing Wooden RSJ With A Metal One? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 05:42 AM   #1
Replacing Wooden RSJ with a metal one?
Hi All,
I have moved into a house with a kitchen that has been extended. The opening in the external wall appears to be supported by a wooden beam and it has a vertical wooden post supporting it right in the middle of the opening. I want to remove the wooden post but have concerns it must be supporting the beam.
Details:
Opening is 2430mm wide.
Questions:
  • Are wooden beam's supporting an external wall like this common?
  • Who should I call to have a look at it to determine if the post is supporting the wooden beam.
  • How expensive do people think it would be to swap wooden beam out for metal RSJ with no support in the middle?
Thanks in advanced for any help on this subject!
Paul
Paul_83uk is offline   Reply With Quote
Old 04-13-2011, 05:58 AM   #2
I have attached an image to help explain. (the kitchen is getting replaced in a couple of weeks)
Old 04-13-2011, 06:51 AM   #3
Old School
Willie T's Avatar
I'm confused.
You say you already have a RSJ (Rolled Steel Joist) beam up there?
If so, where does the wooden beam enter the picture?
Willie T
Old 04-13-2011, 07:59 AM   #4
Sorry I mucked up the title it's just a wooden beam up there not an RSJ. I got a bit "RSJ" Happy when typing the title!
Old 04-13-2011, 09:31 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 582
Originally Posted by Willie T View Post
I'm confused.
At least you knew what a RSJ was.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 04-14-2011, 03:55 AM   #6
Ok rather than picking up I made a mistake in the title can anyone help?
Or at least help with who I need to call to find out if it is structural? Do I really need to call a structural engineer or would a builder be adequate?
Costing to swap out a wooden beam for an RSJ must be fairly simple.
Old 04-14-2011, 06:39 AM   #7
Not so new
12penny's Avatar
Rewards Points: 520
...the fact that the post is there at all tells me that its load bearing. Your builder should be able to tell and offer solutions for removing it.
12penny is offline   Reply With Quote
Old 04-15-2011, 07:02 AM   #8
Thanks Penny,
Thats the conclusion I've made too. I'm calling around the builders today.
Anyone like to suggest how much they think it should cost?
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 10:16 AM
louvered metal door to replace louvered wooden door norfolkgarden HVAC 5 12-19-2010 04:09 PM
install ceiling fan in a suspended metal stud ceiling? amp3d Remodeling 2 09-10-2010 07:55 PM
Replacing Metal Ring Around Garbage Disposal in Sink julbox3134 Plumbing 2 09-15-2009 01:19 AM
replacing metal back borch porch with shingles nurse47557 Roofing/Siding 1 05-21-2008 11:10 PM
