Replacing Wood Support Beam With Steel? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2007, 07:55 PM   #1
Rewards Points: 150
replacing wood support beam with steel?
This house I just bought has a big old wood beam support. It's obviously the "bottleneck" for headroom in the basement. I was wondering if it could be easily replaced with a steel beam that will take up less vertical space?
What about the support pillars? Are those installed on special pads in the foundation? Will steel be able to support a longer span without (as many) pillars?
How is this sort of thing done, is it very expensive? I'm having foundation work done sometime over the summer hopefully, I guess that's the time to do it since they'll probably be jacking the house?
elementx440 is offline   Reply With Quote
Old 02-15-2007, 08:01 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
[quote=elementx440;33617] This house I just bought has a big old wood beam support. It's obviously the "bottleneck" for headroom in the basement. I was wondering if it could be easily replaced with a steel beam that will take up less vertical space? [/qoute]
Steel beam would be about the same width.
could be, or not....depends if the builder used them.
Absolutely.
Not as expensive as you think....If you find the right person to do it. Shop around...
- Build Well -
Old 02-16-2007, 07:50 AM   #3
Rewards Points: 150
But would the steel beam be about the same height?
harleysilo is offline   Reply With Quote
Old 02-16-2007, 07:56 AM   #4
An engineer would be able to answer that.
Try this:
Call a supply company that sells engineered structural steel beams. Give them all the dimensions that they will need (How many floors, home dimensions, joist placement, etc...-they will tell you what they need).
They will then do the structural calculations 'lickity split'....and tell you:
a.) Size of steel beam required for the design and weight load
b.) their cost for the fabrication of such a beam
(FWIW - The steel beams for such an application, that we have dealt with, would be about the same size width or greater...but check into it anyways)
- Build Well -
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 04:55 PM
replacing wood support beam with steel? elementx440 Building & Construction 1 02-15-2007 07:56 PM
Floor Support Beam SlipperyPete Building & Construction 3 12-04-2006 06:55 AM
Steel Beam or Wood Reinforcement for 2nd floor addition? coralhead1 Building & Construction 2 06-06-2006 02:22 PM
drilling a support beam sdmotor Building & Construction 1 07-12-2005 11:51 PM
