Replacing Wood Siding With Vinyl - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 08:36 PM   #31
Ok. Now I'm confused. I have some people helping me, so I know we can do it. I'm getting conflicting advice. I can't put osb over the insulation? Strip it down to studs, put on the osb. Then what? Tyvek? Then siding? What about insulating? I appreciate everyone's input, what's the best way while keeping a budget in mind?
jbjones is offline   Reply With Quote
Old 05-01-2011, 08:45 AM   #32
I think the consensus
What you have is:
Wood Siding - Insulation - Studs with fiberglass between
What is suggested:
1) Remove the siding and the insulation
2) Layer:
Vinyl Siding - Tyvek - OSB - Studs with fiberglass between
If you leave the insulation you would probably have the siding protrude out farther than the windows.
cscpianoman is offline   Reply With Quote
Old 05-01-2011, 03:32 PM   #33
Tizzer's Avatar
Rewards Points: 460
Originally Posted by jbjones View Post
New question. I'm thinking to go ahead and remove old siding and put up osb. The question is would it be ok to put the osb on top the insulation board, then tyvek wrap, or do I have to remove the insulation
Being on a budget, put the OSB on top the foam. The insulation was installed from inside- underneath the sheet rock. Leave it alone. You could pull a pc. of the foam off and have a peek at it where that rotten section was.
You still going to do one side at a time? The Tyvek really needs to wrap around the corners.
Tizzer is offline   Reply With Quote
Old 05-02-2011, 12:23 AM   #34
Registered User
Rewards Points: 526
http://www.greenbuildingadvisor.com/...istive-barrier
http://bct.eco.umass.edu/publication...n-the-outside/
OSB under the rigid foam board, or just not on the corners if you don’t want new trim.
Gary
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 09:20 PM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 09:32 PM
New Vinyl Siding Went From $43k to $15k In A Few Days nycgto Off Topic 12 07-26-2010 11:46 PM
Board and Batten wood siding Knucklez Building & Construction 39 11-07-2008 10:38 AM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 07:43 PM
