Old 05-21-2009, 03:41 PM   #1
Replacing Wood Siding WIth Foam Backed Vinyl
I bought a house last year that was built in the late 80's that has the original wood siding on it. I am going to be replacing the siding with foam backed vinyl siding (already purchased so please don't suggest another form of siding). I plan on removing the wood siding instead of simply placing the vinyl directly over it. My question is should I be adding any additional material besides the tyvek and foam backed siding? I live in Minnesota so we do have the extremes of the weather. Thanks for the help.
xludan is offline   Reply With Quote
Old 05-21-2009, 07:27 PM   #2
Not enough information. Can I safely assume you have 2x6 walls? You should be fine but it wouldn't hurt to add another inch of foam between the siding and the tyvek.
Josh Jaros Remodeling in The Woodlands, Texas
jaros bros. is offline   Reply With Quote
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
Transite Siding Cover Up? Bones Jones Painting 4 04-03-2008 07:14 PM
Vinyl Siding Wolf&Weyana Building & Construction 1 08-30-2006 10:25 PM
Vinyl Siding & windows question blazermaniac General Discussion 6 04-08-2006 01:47 PM
Replacing Wood Panel 4'x8' Siding Chevmann99 General Discussion 5 10-02-2005 08:43 PM
