Replacing Window Sills - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 10:17 AM   #1
Rewards Points: 298
replacing window sills
Hey all,
My window sills are rotting. I think it's called the sill - it's the bottom part. It appears to be a 2x8 type board on a slight outward/down angle. It extends left and right slightly beyond the window frame on the sides.
Some of them in my home are fine. Others are like sponges - I can stick my finger into them an inch or more in a few places. The remaining window parts seem fine.
Is this a DIY job? I'm comfortable with this kind of work. Someone told me "yeah, pull it out, slide in a new one, paint, seal, and secure it and you're done".
When I look at it, I don't see any good way to remove it.
Any ideas or tips?
denemante is offline   Reply With Quote
Old 09-29-2010, 03:59 PM   #2
Use a sazall and cut the sill into tree pieces. The center piece will remove easily and allow you to try out the piece on either side. Cut off or pull nails. Cut new sill to fit slide into place, nail and caulk.
hayewe farm is offline   Reply With Quote
replacing window pain: estimate charges mike1127 Off Topic 1 07-09-2010 09:04 AM
replacing wooden exterior window sills jcharrison Carpentry 5 08-09-2009 12:32 PM
Replacing Brick Window Sills gmac111 Building & Construction 3 06-12-2009 10:54 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
