Replacing A Window With French Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 10:41 AM   #1
replacing a window with french doors
hi there...
i was wondering if replacing a window with french doors in a load bearing wall will be a problem...
i watch enough diy shows to know what i am NOT capable of doing, and before i make any huge mistakes, i thought i would ask the experts!!
i have a window in my bedroom that is 70.5"wide x 42.5" tall, and would like to replace with the same french doors that are in my living room, that also happen to be approx 71" wide... the wall is an outside structural wall, and there is an electrical outlet just below, so i know there will need to be an electrician involved, but will i need to do anything to the structure/frame above the window in order to replace it with a door?? if it is too crazy, i will be having someone do it for me, but i also want to make sure that THEY do it correctly, as i have had some less than ideal contracting in the past... thanks for any input and help!!!
enclosing pictures if i can figure out how!
monicalyn is offline   Reply With Quote
Old 09-12-2011, 11:07 AM   #2
Rewards Points: 6,652
To do it, you are going to have to get a header built to withstand the load. The current header for the window is not going to be enough when you do the french doors. The best thing to do, is interview some contractors in your area and see where they will work with you on if you purchase materials upfront, such as the door. Right now, contractors that build homes are currently doing more remodeling, than before, and are desperate for work.
Old 09-12-2011, 12:36 PM   #3
kwikfishron's Avatar
Rewards Points: 576
If the header is sufficient for the window it also would be for a doors assuming the width of opening will not be enlarged.
kwikfishron is offline   Reply With Quote
Old 09-12-2011, 12:44 PM   #4
Depends on the age of the home, and how it was built. My headers for my windows are two 2x4's placed above with cripples and jackstuds on the sides, due to how they built homes back then in the 30's. I sure would not leave my set up that way, if I was placing a door into the opening. I know that my front and back doors are the same way, due to the age of the home.
Old 09-12-2011, 01:03 PM   #5
Rewards Points: 576
That’s why I said, if the header is “sufficient”.
Old 09-12-2011, 01:36 PM   #6
Of course there are most weekend warriors that take the info on the diynetwork shows and end up getting in trouble. One that I watched Saturday, showed them burying the conduit in the backyard, then the homeowner after not marking the path of the conduit, ended up boring a hole right in the middle of the conduit field. Looked real pretty when they pulled up the bundle of Copper.
Replace Window with French Door--can I do this? tmonte Remodeling 1 08-27-2010 12:29 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
uPVC French Doors foster01 General DIY Discussions 1 02-26-2009 05:56 AM
