Replacing Valley Rafter Without A Roof Tear Off - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 07:57 PM   #1
Replacing valley rafter without a roof tear off
I have a valley rafter that was burned in half, however the general fire damage to the roof is minimal... is there a way I can cut the nails of the rafters that tie into the valley rafter and just slide a new one in? How would I brace the roof during this?
brickandmoss is offline   Reply With Quote
Old 09-03-2012, 06:36 AM   #2
How much of the rafter is left?? Could you sister new ones on either side??
Sawing thru the nails with a sawzall is not too hard. But if any of the plywod has joints on that rafter, renailing them would be difficult. Angle brackets might serve that purpose.
Old 09-03-2012, 10:03 AM   #3
Rewards Points: 2,212
How long is the Valley rafter?
What type of building?
Do you need a permit?
Maybe you could run a "valley rafter" on each side under the other rafters, almost like a beam underneath. On both sides.
mae-ling is offline   Reply With Quote
Old 09-03-2012, 10:08 AM   #4
Framing Contractor
This is not a Diyer project without a professional like a framer or contractor with framing experience doing jobs like this.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-03-2012, 10:13 AM   #5
Framing Contractor
The valley has to be replaced. Half of its burnt. No other way to fix it.
Joe Carola
Old 09-03-2012, 11:50 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 294
I don't see how a valley rafter could be burned that bad and not damage the decking and shingles, you may need to check that rafter again to see just how bad it really is.
If it is actually damaged that bad, check to see if there is a wall under the bad place that maybe could be used to support the rafter.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-03-2012, 12:07 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
if this was caused by fire damage the question is, "do you have insurance?" if so, you should be able to hire a builder to make your home "whole" again.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-03-2012, 05:22 PM   #8
Depending on what type of building, what type of construction, where it is located. There are ways to fix it.
Let's say perhaps it is a shed, no insurance, and the fire did not damage the surrounding area.
Then 'beams' under the rafters on each side of the valley would work. Yes they would be below the top of wall height at the bottoms.
That's why i asked the questions.
Old 09-03-2012, 08:24 PM   #9
Registered User
Rewards Points: 5,492
Let the S.E. have the liability for your safety...
Gary
Old 09-05-2012, 10:39 PM   #10
I would assume you would cut a portion of the roof sheathing to have access from the top. Shore up the rafters on either side of the valley beam. Remove the burnt beam and provide a new beam. Are the rafters hung off of the valley beam or toe nailed?
luckattack is offline   Reply With Quote
Rebuilding a garage roof - rafter vs truss KyleInBrooklyn Building & Construction 30 08-29-2012 06:51 PM
replacing a patio roof - i can't diy eibyer Roofing/Siding 5 05-23-2012 02:13 PM
Missing roof rafter (any reason?) Joe1. Building & Construction 2 09-11-2010 10:01 PM
Replacing peaked roof with a flat roof....? earthtoned Building & Construction 2 01-21-2010 04:28 PM
Cost of replacing a rafter in our roof??? bikerboy337 Roofing/Siding 3 04-24-2005 06:19 AM
