Replacing Two 9x7 Garage Door With One Wide Door - Building & Construction - DIY Chatroom Home Improvement Forum
Closed Thread
Old 08-17-2012, 01:27 PM   #1
First time homeowner
Replacing two 9x7 garage door with one wide door
Hi there, we are looking at fixing up the garage at our house we bought. It has been neglected for years (just like many other things we've found as we've been remodeling). I am ripping off the siding and going down to the frame inside and out. As part of this process, we thought about getting rid of those two doors and installing a 16x7 or similar in their place. Looking at these photos, does it look like the header is strong enough or would I need a new header?
KaiGywer is offline
Old 08-17-2012, 01:30 PM   #2
Rewards Points: 150
No that header will most def sag
Hammer450R is offline
Old 08-17-2012, 01:50 PM   #3
Obviously you can't give an estimate, but are we talking replacement in the hundreds or thousands? To have somebody come in and put in a new header
KaiGywer is offline
Old 08-17-2012, 05:55 PM   #4
Rewards Points: 150
Ballpark is about $800
Old 08-17-2012, 06:21 PM   #5
That sounds cheap....I have a 18' PSL beam for the garage door header....the beam alone was almost $400.....
That looks like a lot of work......
jeepdawg is offline
Old 08-17-2012, 06:40 PM   #6
Framing Contractor
That's pretty funny!
Joe Carola
Joe Carola is offline
Old 08-17-2012, 06:43 PM   #7
Framing Contractor
Obviously the header has supports underneath it in the center. You cannot take those out or the header will definitely fail. You can always install the proper size header for that. You have to have someone design one for you. An architect or engineer can do this.
Joe Carola
Old 08-17-2012, 06:46 PM   #8
Framing Contractor
Impossible to answer. Especially over the internet. Anyone who gives you a ridiculous ballpark or any other numbers is joking with you or just wrong. Read the sticky about this. Just simply have a couple contractors come over and tell you.
Joe Carola
Old 08-17-2012, 06:50 PM   #9
Rewards Points: 150
What is funny? it was a ballpark...$400 for beam and $400 for me for about 4 hours. Its a garage door header with no sheetrock.
Sorry i didnt know about your rules that i couldnt give the guy a ball park like he asked for.
Old 08-17-2012, 08:08 PM   #10
bbo
euro?
pound?
rouble?
bbo is offline
Old 09-04-2012, 07:52 AM   #11
Lightbulb
garage door replacement
We recently replaced our garage door with what looks like a French door. Since the back of our house is driven up to & looks like the front, we have all French doors now. We did everything on the internet, & the guys came up & installed it. We are very pleased, no problems, it looks great, & it has been in place about 3 years so far.
Crazy-Lady
crazy-lady is offline
Old 09-04-2012, 08:48 AM   #12
Framing Contractor
Now you know the rules. Besides giving YOUR ballpark numbers over the internet IS ridiculous. Take it anyway you want.
Joe Carola
Old 09-04-2012, 10:06 PM   #13
Rewards Points: 150
That was when i first signed up...If you got a problem with advise i give on here I'll walk away.
If my advise helped you hit "Thanks"
Old 09-05-2012, 07:02 AM   #14
Rewards Points: 125
That's going to take something substantial, you not only need a header to span a 16' opening but one along the wall supporting the roof load. ND- North Dakota? Man, I hate to even think how much weight of snow might be sitting on that roof, especially with the relatively shallow pitch of it. I spent several years in ND one winter and that weather is not to be trifled with, I'd be hesitant to go to a 16' just from wind concerns.
You are going to have to get a SE's opinion, this is not a simple "tear it out and throw up a beam" job.
ThatDaveGuy is offline
Old 09-05-2012, 08:28 AM   #15
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Just hire a contractor to do it. When he hands you the bill - if it's more than $800, just tell him that Hammer450R from the internet said it should only be around $800.
CoconutPete is offline
Closed Thread
Garage door removal bmorekid Carpentry 2 12-31-2011 10:18 AM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
Garage Door Opener Help jwysocki General DIY Discussions 1 04-10-2011 04:28 PM
Replacing garage side door Towny Remodeling 5 02-05-2010 04:38 PM
Garage Door Opener Help chard General DIY Discussions 5 02-03-2010 05:06 PM
