Replacing Studs With Pipe In The Way - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 09:15 PM   #1
replacing studs with pipe in the way
How can I replace studs in a shower when existing pipe is in the way? The old studs are rotten at the bottom, but they also have a pipe and a wire drilled through them.
spiffyman is offline   Reply With Quote
Old 11-13-2010, 09:19 PM   #2
joed's Avatar
Rewards Points: 11,992
1. Remove pipe and wire and drill hole in new stud.
2. Remove only bad part of stud. Put filler in and then sister a piece new 2x4 to span the joint. Glue and screw together.
The Following User Says Thank You to joed For This Useful Post:
spiffyman (11-13-2010)
Old 11-13-2010, 09:25 PM   #3
Thanks for the quick response - I'm not 100% sure which I will do yet - #2 is certainly easier, but I may want to take the wire and pipe out to drill so that can I add another stud to slightly expand the shower width.
Old 11-17-2010, 06:48 AM   #4
go with option 1 ,just take the wire and pipe out ,replace the stud and drill new holes for pipe and wire.You will thank yourself down the road and a new stud aint that expensive.The moisture may have wicked up so far on the stud that you would need to drill new holes anyway so do it now.I could see sistering for a little rot in something like a floor joist but a bathroom wall stud ...come on man (as they say on gameday )
clasact is offline   Reply With Quote
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
Replacing pipe leading to baseboard radiators Donbee HVAC 1 03-05-2009 03:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 07:47 PM
