Replacing Stud Wall Behind Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2008, 07:56 AM   #1
Question
Replacing stud wall behind brick
I need to replace a stud wall that consists of tyvek and osb on the outer skin. My question is how do you re-attach the brick ties to the new wall? I don't want to demo the brick and plan to build the new wall on the floor and lift it into place after supporting the existing ceiling joists. (That's my plan anyway). Anybody ever had to do this? What did or would you guy's do? Thanks in advance.
bayoudonnie is offline   Reply With Quote
Old 05-19-2008, 10:34 AM   #2
concretemasonry's Avatar
Rewards Points: 2,578
The stud wall you are trying to replace is actually the back-up or support for the brick veneer. It is necessary for all the ties to be in place to connect the veneer to the structure.
I don't know what kind of code enforcement you have, but it would probably be cheaper to rebuild the veneer to get a proper wall in the end.
From a practical standpoint, I inspected over 600 homes damaged from Katrina. Even though the veneer is technically supported by the studs, I saw a dramatic difference in the danage from Katrina and Rita. - The veneer actually provides support and rigidity.
The homes with flimsy siding (vinyl, wood) were racked and twisted to the point of being useless even if the mold and moisture did not ruin the wood. The homes with brick veneer (even only patial height or several walls) had far less damage and cracks and could be repaired. This was due to the stiffening provided by the masonry properly attached to the "structure". This was common in Slidell that had a lot of water/surge and the west bank of N.O. that only had the wind and roof damage.
Without seeing you home or knowing if any codes must be met, it is impossible to give you a specific method of attaching existing veneer to a new wall built later. The important thing is that the veneer must be attached in order for the veneer to give you the benefits. Since the veneer is very rigid, you could end up with many cracks as the wood stud wall shrinks and finally gets into its place and the eventual wind loads come around again.
concretemasonry is offline   Reply With Quote
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 03:45 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
