Replacing A Storage Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 11:29 PM   #1
beans50's Avatar
Replacing a storage shed
Well I'm replacing a shed in my backyard. It has a cement foundation already that is roughly 12'x20'. I don't want anything fancy or anything, just a basic wood shed. I also want to put in a pull up garage door (no motor though). It sounds really easy and I have an idea how, I just want some suggestions and maybe a rough estimate of how much wood i will use on the frame
beans50 is offline   Reply With Quote
Old 02-22-2012, 12:22 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Allow 1 stud per lineal foot
Perimeter measurement x 6 stock 2x
Don't forget treated plate
2 dozen 2x6x16
40 sheets 7/16" osb
Pretty close.
titanoman is offline   Reply With Quote
Old 02-22-2012, 12:29 AM   #3
Registered User
Rewards Points: 5,216
And one pull-up garage door.
Please ask identical question in only one forum, I removed your duplicate thread, thanks, Gary
Old 02-22-2012, 12:34 AM   #4
Rewards Points: 13,296
If you go to Lowes or Home Depot they can design one right on the computer and come up with a material list.
Make sure to use Adavntec for the sub flooring. Far less likly to rot out.
If you go with wooden siding like T-111 use solid stain not paint so it does not start peeling off after the first year.
DO not have the siding within 6" of the slab or ground or it will rot out.
Install a ridge vent to reduce heat inside and help the shingles last longer.
Have at least a 6" over hang on the roof on all sides and the siding will last longer.
Correct way to wire a shed / workshop BOAH Electrical 10 01-05-2011 11:03 PM
RV Storage shed wiring cewatson Electrical 0 12-06-2010 01:07 PM
Storage Shed Retainer Wall cmlatch Gardening Forum 4 04-03-2010 07:44 PM
Base for Storage Shed cbsrugby Building & Construction 6 05-08-2008 02:41 PM
