Replacing Spiral Staircase - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 08:50 PM   #1
We are looking at purchasing a home that has a spiral staircase leading to a loft that can be converted to a third bedroom. We want to replace the spiral staircase and are wondering about the cost/labor involved. Is this a DIY project or something that needs to be contracted out? How hard is it? Is there any place that sells precut stringers? Thanks for your advice!
Floridahome is offline   Reply With Quote
Old 01-16-2011, 09:10 PM   #2
If theres a spiral there its probably because of room restraints. Why in the world would you want to get rid of a spiral. Is it a cheap diy one or a site built one? There expensive to build. A new stair case is not a dyi unless youve had some experience in staircases you can really mess one up bad.
ubenhad4 is offline   Reply With Quote
Old 01-16-2011, 10:27 PM   #3
Rewards Points: 198
try ez-stairs. i've just built a set of stairs instead of a spiral staircase solution. turned out pretty good
vote4Pedro is offline   Reply With Quote
The Following User Says Thank You to vote4Pedro For This Useful Post:
Floridahome (01-17-2011)
Old 01-17-2011, 07:21 AM   #4
Thanks for the great advice! We'll check it out.
Old 01-17-2011, 06:26 PM   #5
Once I put together one of those oak spiral kits you see advertised in the back of Pop Sci. and other mags. I am a carpenter, but if you can follw directions, you can do this. Don't be afraid. Just finish step 1 before you start step 2. Make sure you got the right heighth before you open the box.
Dwoodsmith is offline   Reply With Quote
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 05:53 PM
Half-Wall/Sub-Wall around Spiral Staircase Herlihey Carpentry 7 02-03-2010 10:25 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Spiral staircase possible with 20" x 21" opening? t_bunson Building & Construction 12 09-09-2008 06:18 PM
Spiral staircase questions NateHanson Building & Construction 3 01-20-2008 08:49 PM
