Old 07-22-2010, 07:53 AM   #1
Replacing a sliding glass door with a new window
I am getting ready to replace an old sliding glass door with a new window, but have a few questions. Here is where I am. The old window is about 8’ W x 7’ H. I am replacing it with and Anderson 3 pane casement window that is 72” W x 41” H. I am planning on leaving the header in place and then framing the area out for the new window and wall. Here are my questions:
1. The rest of the house (70 + yrs old) is not wrapped with Tyvek or any other house wrap under the wood shingles. Or I should say I am not sure if the rest of the house is wrapped. Does it make any sense to wrap this small area? If so should I use Tyvek or tar paper?
2. Is ½” OSB acceptable for the exterior walls or do I need to use plywood?
Any other tricks or suggestions would be much appreciated!
Thanks,
Ian
twildey is offline   Reply With Quote
Old 07-22-2010, 09:40 AM   #2
A "Handy Husband"
rjniles's Avatar
1. I would cover the framed in area for water proofing and draft resistance. Every little bit helps. Use 15 pound felt (tar paper) to save buying a roll of Tyvek.
2. OSB is fine as long as nothing in a local code rejects it. I have not heard of an area that does.
Coastal South Carolina
Replacing a HUGE sliding glass door w/ a hinged patio door. ZeroTX General Discussion 12 05-02-2013 11:39 AM
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 06:01 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Replacing glass in older aluminum storm window gt2003 General Discussion 3 11-26-2008 10:07 PM
