Replacing Slab, How To Replace Under Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-02-2009, 07:46 PM   #1
weekend warrior
Rewards Points: 150
replacing slab, how to replace under stairs
I'll be replacing my basement slab in the spring. I plan on replacing the stairs as well after the fact.
What's the normal practice to have the concrete extend under the old stairs, instead of of cutting around it and pouring upto the existing old concrete?
Remove the stairs once the pouring begins and they can escape with a ladder? How's everyone else handle this?
johnny331 is offline   Reply With Quote
Old 01-02-2009, 07:57 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
get your self two 2x4's and secure the tops to the floor joists above on each side of the stairs, then secure the bottom of the studs to the bottom of the stairs. I cut the bottom step out so to give the concrete contractor room to float the slab. thus making the stairs hang from the 2x's BOB
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
Replace or keep baseboard moldings when replacing doors? J187 Building & Construction 3 09-15-2008 01:36 PM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 10:50 AM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
