Replacing Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 03:19 PM   #1
Rewards Points: 578
Replacing siding
i did a thorough inspection on my siding yesterday. Its in worse shape than i thought, and i dont think most of it will work as underlayment for vinyl. So, im thinking it might be better to put up new smartpanel siding and forget the vinyl. Ive got two questions.
1. What is the easiest way to hold the 4'x8' panel in place while i nail it up? Its much too heavy and a simple 2x4 wont work like it does for a cabinet.
2. How do i seal it at the top? There is no overhang of the roof, and it doesnt leak at the present time, and i would like for it to continue to be waterproof. Ive included a few pictures i found of the outside, and you can see the lack of eaves and bad condition of the siding.
Current siding is T-111. I had originally planned to replace it with vinyl, but now planning on using Smart panel cement fiber siding.
Please help, any advice will help!
Replacing siding-bedroom-end.jpg   Replacing siding-kitchen-end-back-house.jpg
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 02-25-2013, 04:25 PM   #2
Rewards Points: 578
Anybody?
Old 02-25-2013, 04:32 PM   #3
Not so new
12penny's Avatar
Rewards Points: 520
Are you taking off the old rotten stuff?
12penny is offline   Reply With Quote
Old 02-25-2013, 04:47 PM   #4
Rewards Points: 578
yes i am
Old 02-25-2013, 04:53 PM   #5
Not so new
12penny's Avatar
Rewards Points: 520
Then I would think it'd tuck
up under the existing flashing.
And you'll need a helper to
get those panels up and steady
till you get a few nails in.
Old 02-25-2013, 05:12 PM   #6
Rewards Points: 578
thanks
Old 02-25-2013, 05:26 PM   #7
Rewards Points: 12,818
Smart panel is not a cement siding, it's treated OSB.
Use ring shanked siding nails or galvinized spiral nails.
The siding nails are best because of the smaller head.
Measue how tall that wall is, it only comes in 8' panels.
Not likly your going to be able to get the siding in under the seam at the roof line. Just use the Z moulding made for T-111.
12penny (02-25-2013)
Old 02-25-2013, 06:06 PM   #8
Rewards Points: 150
I'm assuming that's why there is the freeze board under the gable to break up the seams. Yeah def want up get under everything even if u dado the bottom of new freeze and flash over top of it so new piece goes over flashing to keep water tight. Don't want to rely on over applied caulk
kaschmid3 is offline   Reply With Quote
Old 02-25-2013, 07:00 PM   #9
Not so new
12penny's Avatar
Rewards Points: 520
Get rid of the frieze board.
Use galvanized z flashing
as joe suggested.
Old 02-25-2013, 08:07 PM   #10
Rewards Points: 616
are you going to replace windows? when you reside it would be the best time to do that
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Old 02-25-2013, 09:48 PM   #11
Your going to say you can not afford but this is a great material to use instead or those boards that are up there now.
No more painting or rot to deal with.
Just install so the datto is on the bottom so the siding can be slid into it.
Old 02-25-2013, 11:12 PM   #12
Rewards Points: 154
To hold up a 4x8 panel myself I usually attach a short length of 2x4 horizontally at waist level to a act as a handle. I use a couple screws to attach it, and putty the holes when I go to paint.
ovahimba is offline   Reply With Quote
Replacing Hardiplank siding... herbtown Roofing/Siding 4 08-19-2015 12:37 PM
Replacing old siding panels giappino Building & Construction 5 11-23-2010 08:39 AM
certainteed cement siding cracking! wichitawings Building & Construction 23 11-04-2010 07:55 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
