Old 06-20-2011, 10:01 AM   #1
replacing rotted sill in garage
how do I jack up my garage to replace the sill
David White is offline   Reply With Quote
Old 06-20-2011, 12:04 PM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Ooohh, not even enough information.
Can you be more specific about what it is you are trying to do?
Maybe a picture or two?
Andy.
AndyGump is offline   Reply With Quote
Old 06-20-2011, 02:47 PM   #3
Very carefully.
Definitely photos.
Ron
B. Franklin 1759
Old 06-20-2011, 07:06 PM   #4
IF it's just a slab, and depending on how much needs to be done.....you can build a temporary supporting wall inside the existing wall. then cut out the old sill and any bad studs, and replace with PT.
But, as mentioned, pictures would make this easier to answer.
1910NE is offline   Reply With Quote
Old 06-21-2011, 06:57 AM   #5
door sill OR sill plate ?
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
how to fix rotted sill plate carole2cd Building & Construction 7 03-26-2011 07:19 AM
Replacing Garage door. Can I do it? Alan General Discussion 9 02-12-2010 05:27 PM
rotted sill plate Skippymartinez Building & Construction 4 06-02-2009 06:29 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 10:43 PM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 11:23 PM
