Replacing Rotted Exterior Trim - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-18-2014, 04:06 PM   #1
Rewards Points: 275
Replacing rotted exterior trim
this may be a stupid question but i want to replace a couple pieces of exterior wood trim and was wondering if i need to use pretreated wood or regular ole white wood so long as i use the right primer and paint.
on that note, what type of primer does one use for exteriors? also what kind of caulk is best?
thanks!
marcus118 is offline   Reply With Quote
Old 11-18-2014, 04:39 PM   #2
Rewards Points: 114
I would grab some fake wood, prime with an exterior primer. Ron
ront02769 is offline   Reply With Quote
Old 11-18-2014, 04:42 PM   #3
Rewards Points: 12,858
Not stupid, just not enough info.
What trim is it? Fascia, window, brick moulding, ECT.
Got a picture.
Often times if it rotted it was the wrong type trim, installed wrong, or there's a better way to do it so it never rots again.
Old 11-18-2014, 04:44 PM   #4
Rewards Points: 275
Got a picture.
window trim.
Old 11-18-2014, 04:46 PM   #5
Gymschu's Avatar
Rewards Points: 232
Just be sure to prime all sides of the trim before installing. Any real paintstore has quality latex primers for wood. As for caulk, I like what I get at Sherwin-Williams:
Gymschu is online now   Reply With Quote
Old 11-18-2014, 09:54 PM   #6
Open it up then give us a picture, looks more then just trim.
ron45 is offline   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
joecaption (11-19-2014)
Old 11-19-2014, 01:45 AM   #7
I agree, looks like that old wooden drip edge is shot to.
All of that can be replaced with vinyl.
All that damage likely came from not priming and painting the end grain of the trim, installing it tight to the drip edge, then someone caulked it forming a dam holding in water.
Old 11-19-2014, 08:09 AM   #8
Rewards Points: 275
yea i'm going to be putting siding on the house within the next year so it will be fixed with vinyl. but until then im just looking for a temporary fix since it looks so bad.
Old 11-19-2014, 08:31 AM   #9
AHH, SPANS!!!
Rewards Points: 1,166
temp fix- Bondo. clean all the loose rot out and then add nails or trim screws in the open cavity to give the bondo something to grab to then bondo. paint it when it dries
hand drive is offline   Reply With Quote
Old 11-19-2014, 10:01 AM   #10
Quick fix.....
clean out the opening, shoot with foam, cut off access, paint.
Old 11-19-2014, 10:11 AM   #11
Rewards Points: 275
Originally Posted by ron45 View Post
Quick fix.....
what kind of foam?
Old 11-19-2014, 10:25 AM   #12
I agree, with cleaning it out and using the Bondo, or a easy less expencive way is with Durham's Rock Hard Water Putty, no foam!
RockyMtnBlue (11-19-2014)
Old 11-21-2014, 12:14 PM   #13
Rewards Points: 402
Bondo is a good option if damage is small, but if the area is big then you need to replace the entire sill.
fortunerestore is offline   Reply With Quote
Repairing Rotted Storm pclimber Windows and Doors 1 10-14-2012 11:31 AM
Best way to repair rotted structural wood member? miamicuse Carpentry 20 11-19-2011 05:30 PM
Replacing water line for refrigerator seannymurrs Plumbing 13 04-09-2011 07:30 AM
Rotten Rotted Header! jlatulippe Building & Construction 1 10-06-2010 09:28 AM
Help: Rotted wall joists, wall frame plates, subfloor smallblockchevy Remodeling 8 07-22-2008 07:14 AM
