Replacing Roadside Mailbox. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 05:35 PM   #1
Rewards Points: 164
Replacing roadside mailbox.
The existing mailbox is probably 40 years old and it looks it. It is rusty tilted and with chipped paint. Now the plan to change this should I place box in NEW hole or keep the same one and fill with quick concrete (since it wasnt the first time). Next should I use pressure trated wood for the post or not and do you( the members) think it would be better to get a metal or plastic type mailbox-----> this part may be our preference.
68MHJCs is offline   Reply With Quote
Old 08-10-2009, 07:55 PM   #2
Drywall contractor
Rewards Points: 1,070
I'd go with the same hole. When you pull the old box out, half the work is done. Dirt is broken up nicely making for easier digging of new hole. I've always had wood posts for my mailboxes (PT 4"x4") mainly because I can make them myself and just add the old box or a new one as needed. I set mine with a bag of "Sakrete" to keep it steady. Metal or plastic is your choice.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-10-2009, 08:28 PM   #3
Rewards Points: 164
thanks
Thanks for the info...its my next project to do shouldnt be a big one but just finsihed putting 16X16 swingset/slide play area for child in back yard need an easy one next.
Old 08-11-2009, 08:53 AM   #4
Drywall contractor
Yeah, those big wooden swing set/play areas can be quite a daunting task.....
Alternative to replacing appliances neondanger Appliances 1 06-27-2009 11:01 PM
Replacing Light Switch & Outlet, but now I'm confused. ego1138 Electrical 7 04-25-2009 05:49 PM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 09:11 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
