Replacing A Portion Of A Concrete Slab? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 01:46 AM   #1
Replacing a portion of a concrete slab?
I have a studio apartment that is on a slab that is a compilation of two poorly poored slabs. There is a 5'X5' area in the center of a room that I am planning to cut out and re poor.
I dont know much about concrete but I plan to make a 5'X5' square hole and drill holes to glue 3/8" rebar into the existing concrete and poor new concrete into the hole.
How deep do I need to drill the rebar into the existing conc. What kind of glue should I use?
Do I need to do something for a moisture barrier? If so what should I use?
Any other tips?
Thanks!!!!!
Dave
Dave K is offline   Reply With Quote
Old 04-18-2011, 08:36 AM   #2
Rewards Points: 4,534
1st, can you do this work legally w/respect to condo restrictions ? as a genl rule, all slabs-on-grade should have vapor barriers installed,,, currently the spec is 15mil ( stego is oft spec'd ),,, whether or not you need #3 bar is another issue - i would core holes 2x deep as the slab is thick ( eg, 4" slab = 8" deep ),,, the cured elevation may differ from the existing meaning you'd have to grind or overlay for proper alignment.
epoxy will secure the bar to the existing conc ( properly clean the hole ) but deformed steel is always recommended,,, don't know if this is avail in #3 bar to you.
Old 04-18-2011, 07:00 PM   #3
Knucklez's Avatar
Rewards Points: 930
don't "cut" the concrete. the nice eaven clean seam that a saw would make does not provide for good adhesion to the new concrete. use an electric rotary hammer and the edges will be rough, 3-dimensional. so there is lots of area and adhesion and no leaky seam.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 04-19-2011, 06:13 AM   #4
what 'nuck's talking about is ' mechanical [ or aggregate ] interlock ',,, despite anyone's best intentions, fresh conc doesn't bond to existing however, if the edge is left jagged as is case when using a breaking gun, there will be some ' holding ' power from the irregular edgewall,,, any liquid conc will shrink upon curing therefore no bonding's gonna happen.
since its an interior slab, there'll be little change in floor dimension from changes in temp but you will see a slight crack between old & new
Old 04-23-2011, 10:53 PM   #5
Knucklez's Avatar
Rewards Points: 930
concrete dude. .. i'm a bit confused by your post. i think you are saying that due to concrete shrinkage the new concrete will still leave a crack or seam despite leaving a jagged edge. if that's the case then how do you do this properly ( i don't know, never done it before) ? just cut with a saw a nice long seam and then seal it later with masonary caulk? cutting with a saw is a lot of dust, so maybe smashing is still better, but still will end up having to deal with a crack/seam after the concrete drys?
Knucklez
Old 04-24-2011, 07:50 AM   #6
yes, said that & still mean it,,, there will be TWO pieces of conc in the final floor no matter how properly its done,,, sawing the conc ( we have dust shrouds on our saws, guns, & drills hooked up to vacs ) ^ sealing the sawcut still doesn't camouflage it same w/sidewalk replacement or conc hgwy slabs - now go chase a bunny
How to install conduit in concrete slab mthabault Electrical 4 02-24-2010 11:57 AM
insulating exterior of concrete slab home.. rvegab00 General DIY Discussions 5 10-15-2009 10:26 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
