Replacing Porch Posts With Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2013, 08:04 AM   #1
Replacing porch posts with beam
We want to remove four posts holding outer 16' side of 15 by 16 (width) porch roof. Rafters currently supported by doubled 2x6s 16 ft long with 4x4 posts on each end. Under the doubled 2x6 beam there is a 4x4. This has supporting posts every 3 feet (four posts). Essentially what we have is a 3 1/2 by 9 (5 1/2 doubled 2x6 and 3 1/2 4x4) beam with six posts.
I would like to remove the 4 middle posts, add 4x4 posts just inside the outer two posts to support a 15' 5" doubled 1 3/4 lvl under the 4x4. I would then enclose the entire (3 pieces stacked) beam to make it look like a single beam and protect the lvl from the elements.
What depth lvl should I use? Trying to minimize drop.
Any other suggestions? Possible aLternative to replace the 4x4 beam with doubled 1 3/4 x 9 1/4 lvl? This is in Georgia with only occasional very light snow.
Thanks for advice.
Baseball1970 is offline   Reply With Quote
Old 10-15-2013, 12:57 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
what is your exact location? Snow load in GA range from 0 psf to 10 psf. Also would need to see a picture of how its attached to your house, the tributary area of your roof (for drifting snow conditions), rain on snow surcharge, etc....
You will also have to take into consideration the load concentration that you will now be creating at your new post locations. You will no doubt have to demo the footer that is there (assuming there is one) and pour a new bigger footer to handle that load.
I think you would be better off paying a local structural engineer a couple hundred bucks to come out and size the beam and footers.
brockmiera is offline   Reply With Quote
The Following 2 Users Say Thank You to brockmiera For This Useful Post:
Live_Oak (10-15-2013), woodworkbykirk (10-15-2013)
Old 10-15-2013, 07:22 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
also most regions dont allow 4x4 posts any more to act as bearing posts.. they can buckle under heavy wind loads. 6x6's are the standard now. 4x4s are used for hand rail posts
woodworkbykirk is online now   Reply With Quote
Old 10-16-2013, 06:13 AM   #4
you need a structural engineer to spec the size of everything because you need to pull a permit for this and they want to see your plan all laid out.
framer is offline   Reply With Quote
porch post and beam detroittigerfan Building & Construction 8 10-04-2013 08:35 AM
Triple 2x10 beam has twisted WillK Carpentry 11 12-28-2011 11:50 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Replacing Porch Columns mcwolfe6 Building & Construction 8 05-12-2010 06:51 PM
Replacing wood posts with Lally Posts Rugbymuffin Building & Construction 1 03-05-2009 10:14 AM
