Replacing Plywood SubFloor ... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 09:49 AM   #1
we're renovating (go figure) ... and in pulling up the flooring (laminate, linoleum, you name it ... I've noticed several places where there's water damage to the plywood subfloor. not to mention the smell ... (1969 built home).
was just wondering about replacing the subfloor ... does the thickness of plywood differ that much? when would you use 1/2", 3/4" and 5/8" ? should I use tongue & groove? I'll definitely glue & screw - can't stand squeaks ... but was just wondering when you use which thickness.
any info would be great. thanks!
njchan is offline   Reply With Quote
Old 02-01-2010, 10:47 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
Ayuh,... You've got to figure out the Final height you want,+ then build up to it...
Subfloor + underlayment + flooring should equal the height necessary to match whatever is surrounding the area you're workin' on...
Old 02-01-2010, 01:38 PM   #3
47_47's Avatar
Rewards Points: 62
Use 3/4" t&g for your subfloor, glued and screwed.
47_47 is offline   Reply With Quote
Old 02-01-2010, 03:32 PM   #4
thanks for the info - I guess I thought the thicknesses were for different applications ...
i.e. if the joists were 12" oc you can use something thinner (1/2") or if the joists were 16" oc you should use 3/4" ... or if you were going to apply tile, hardwood, etc blah blah blah.
thanks for the info.
Old 02-01-2010, 04:57 PM   #5
is ply bad or is it just smell. If just smell look into sealing ply or replace bad sheets and seal
Subfloor repair Dave321 Flooring 3 09-16-2009 08:59 PM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 09:50 PM
replacing subfloor for tile upgrade bucaronco Flooring 5 07-29-2009 04:35 PM
Information needed on replacing kitchen subfloor lyren1970 Flooring 2 07-17-2008 01:03 AM
Replacing my subfloor DanBress Flooring 17 02-16-2008 09:11 AM
