#1 |
replacing parts of cast iron vent stack
i am copying my post from plumbing here because it deals with both plumbing as well as structural matters. please respond on the target post if you can. admin, please do not remove this copy.
replacing parts of cast iron vent stack thanks |
#2 |
"Nail-Bender"
The suggestion in your post in "Plumbing", concerning using "Riser Clamps" -
is the way to go. Have done it before - it works. If you think you can get away with one - use two! rossfingal |
| Display Modes | |
| floor drain / cast iron to pvc? | n2learning | Plumbing | 3 | 08-01-2010 07:20 PM |
| Kohler vs. AS cast iron bathtubs? | VinDan | Plumbing | 5 | 07-31-2010 02:48 PM |
| Vent stack is on other side of basement... | Feretich | Plumbing | 5 | 02-12-2010 02:13 AM |
| Backing off OLD galvanizd pipe...& PVC to cast iron | michael76 | Plumbing | 13 | 02-18-2009 12:18 AM |
| Corrosion problem in vent stack. | sgbotsford | HVAC | 2 | 12-01-2007 03:47 PM |
