Replacing Old Basement Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2009, 03:12 PM   #1
gruntman's Avatar
Rewards Points: 79
Replacing old basement windows
I have 3 windows I need to replace. Two of them have rotting sills and the other is old and lets in bugs. See attached photos. I was given a quote of around $900 to replace all three with Silverline 5900. Are these quality windows? Whats better? Is this a DIY job or something best left to pros?
Replacing old basement windows-img_5570.jpg   Replacing old basement windows-img_5571.jpg   Replacing old basement windows-img_5574.jpg   Replacing old basement windows-img_5576.jpg   Replacing old basement windows-img_5572.jpg
gruntman is offline   Reply With Quote
Old 05-16-2009, 10:54 PM   #2
Registered User
Rewards Points: 5,242
If that's a living space in basement, I would ask if you had egress (escape) in case of fire, other than those windows. (Too small and too high)
Lots of work, rebuilding sills and jambs. Did anyone bring this up? Be safe, G
Old 05-17-2009, 07:31 AM   #3
gruntman's Avatar
Rewards Points: 79
It's an office. There is a door in the back that could be used for escape. Right now the windows are shut tight with paint. It would be nice to be able to let in some fresh air.
2 of the 3 windows are going to be surrounded by a well. They both have rot on the sill. The other gets pretty good light. Is there a better choice than Silverline?
Old 05-17-2009, 08:23 AM   #4
One option that's used often in my area is glass block. Several styles available. They can be purchased pre-made to the size of the window so all you do is mortar them in. (Buy a $5 morter bag to squeeze in the morter around the perimeter). Or you can buy the glass blocks individually and morter them together yourself. you can get a vent insert to crank open for fresh air as well.
Mosy DIY stores carry them or will order what you want. For pricing, in my area a basement window ranges from $55 to $85 for the DIY'er. Around $150 installed. Prices will vary depending but that's the option I'd go with.
Worth looking into IMO.
Shamus
Shamus is offline   Reply With Quote
Old 05-17-2009, 10:01 AM   #5
tough job!
it will be a one big job.
thanks for all our contractors to handle all this dirty and tough jobs.
mortizallen is offline   Reply With Quote
Old 05-17-2009, 10:21 AM   #6
Its not that bad of a job really the hardest part will be getting all the rot out but from their its pretty stight forward,so yes a DIYer could do it.As far as the type window I have seen them but dont know alot about them or who makes them.Some company names are just a subsituary of another company or a bigger company.Sort of like antifreez their are only two plants that make the stuff but how many differnt barnds do you find in the store.I put grandview in my home and when I compared them to Andersons they were neraly the same so that part is on you unless someone else has a opinion of that company.Personally for that size window I like the ones that slide side to side instead of tilting in but again your choice your house
clasact is offline   Reply With Quote
Replacing Windows (Which Brand?) dixieman Remodeling 3 04-30-2009 07:45 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Replacing old steel basement windows in a poured foundation? bergmw1 General DIY Discussions 3 03-08-2009 06:16 PM
Basement windows above floor joists billthecat Building & Construction 7 10-20-2008 09:07 AM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 11:23 AM
