Old 03-01-2009, 06:10 PM   #1
Replacing mylar windows with vinyl windows
I live in Southern California and have an attached den with "mylar" windows. I would like to replace these windows with double pane vinyl windows. One side is abt. 21 ft., the other side is abt. 13 ft. The opened window space is abt. 4'6" above a 30" wall. To do a go job, I think I might need to build a frame, place it between the wall and the roof, in order to purchase presized windows to install. What do you think?
turkeybday is offline   Reply With Quote
Old 03-02-2009, 07:03 AM   #2
Man of many hats
wrangler's Avatar
That is one option, another would be to use horizontal sliding windows. With sliders, you could use a wider window and only need to add some vertical supports. With the sliders you'll have more glass space for a less obstructed view. If you dont need them all to be able to open, you could also go with a combination of picture windows and sliders, double hung, or even casements.
Man of many hats
wrangler is offline   Reply With Quote
Vinyl Replacement Windows fixiechick General Discussion 56 04-20-2009 06:37 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 11:03 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 11:23 AM
