Replacing Main Carrying Lvl Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-03-2014, 12:57 PM   #1
Rewards Points: 4,442
Replacing main carrying lvl beams
per engineer's report, we have to replace 3 lvl ( 2 x 10 ) beams + 2 2x10's scabbed alongside as they've twisted a bit,,, we just installed 2' x 2' x 1' steel-reinforced foundations yesterday to replace some sort of apron/vest pre-cast ' thingie ' made to fit 6" x 6" p/t'd columns.
this is the main carrying beam for the house - we're using 4 lvl's - the engineer wants them bolted together w/1/2" bolts,,, he didn't specify carriage or other.
sound good ? thanks in adv !
Old 03-03-2014, 03:57 PM   #2
joed's Avatar
Rewards Points: 11,518
You will not get anyone here to disagree with an engineer.
Old 03-03-2014, 04:03 PM   #3
even tho his initials are ' pe ', it doesn't appear home inspections are his specialty from his report which the owner sent,,, all i'm asking is how best to join the lvl's - i do appreciate your comment & agree
tnx
Old 03-03-2014, 04:12 PM   #4
Rewards Points: 256
I always use construction adhesive and truss loks
JustinK is offline   Reply With Quote
Old 03-03-2014, 04:18 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
Each engineered wood manufacturer (iLevel, Boise, etc.) have their own recommendations for joining multiply members, especially when side loaded.
See who made the members and check out their website.
or ask the PE, after all it's their design.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-03-2014, 04:27 PM   #6
always thought truss locks were something male athletes had to wear i shouldda thought to ask the lvl manufacturer fwiw, engineer doesn't return phone calls or answer e-mails,,, same w/selling broker & owner who's the seller have an idea he certainly deposited the buyer's check quickly tho
thanks guys - APPRECIATE THE KICK-IN-THE***
Old 03-03-2014, 05:05 PM   #7
Civil Engineer
Rewards Points: 4,514
I am going to hazard a guess that the engineer is not under contract to you, but prepared the plans for someone else. If the plans fail to include a detail on connecting the LVL's, I would talk to to the building inspector first to see what they want to see. My building inspector loves Truss Loks, but some building inspectors do not know what they are, and will not approve them. Typically if using bolts, you will need to use standard steel bolts with double nuts to prevent loose nut syndrome. Some inspectors will allow use of a lock washer plus a single nut. A few may even allow use of Nylo nuts or perhaps Lok Tite. In the end it is the building inspector's call if the plans do not specify technique.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
replacing main breaker box rebelbull Electrical 8 01-18-2012 02:20 PM
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 05:46 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Replacing part of the Main Water line rgmetro Plumbing 2 04-12-2007 09:30 AM
Replacing main through foundation Jlauck Plumbing 6 08-03-2006 08:22 AM
