Replacing Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 08:17 AM   #1
Rewards Points: 164
Replacing load bearing wall
I need to replace a load bearing internal wall. It had a wall furnace in it and is actually cut thru where the vent went into the attic.
The wall is 10' long and has about 5' walk way.
I was thinking of doing this:
- use 4x4's on both ends as temp supports
- then tear out the 2x4's
- build the header
- build the supports and leave the 4x4's on the end
My concern is two things
- the cut in top for the furnace vent as it's 4" from the end of the wall
- no real support in the middle of the wall while I'm building the new supports
Above the wall is the ceiling joist the run perpendicular (90deg) to the wall, so I could put temp bracing on each side of the wall, put up the wall and remove the temp bracing.
Also, the new furnace is going on the side of the wall, not thru the wall so as to not cut thru the header.
KarlJay is offline   Reply With Quote
Old 01-05-2011, 01:35 PM   #2
You absolutely must built temporary walls on both sides.
pyper is offline   Reply With Quote
The Following User Says Thank You to pyper For This Useful Post:
glkirk (12-27-2013)
Old 01-05-2011, 04:17 PM   #3
Rewards Points: 164
Thanks, that's what I was thinking. Last thing I need if for this to fall down.
Old 01-05-2011, 05:03 PM   #4
cocobolo's Avatar
Rewards Points: 5,674
In case you need any reinforcement, the man is exactly right. All you need to do is to leave yourself enough room to get at the replacement wall/beam structure and you'll be just fine.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 12-27-2013, 04:44 PM   #5
Don't forget to ensure your jack/point loads are transferred and blocked appropriately all the way to footing.
glkirk is offline   Reply With Quote
Load Bearing Wall Removal Question! Please Help! Evil Scotsman General DIY Discussions 2 10-25-2010 05:52 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 05:25 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Load bearing wall in basement Ezekiel Building & Construction 3 11-12-2008 10:23 PM
