Replacing Lallys - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 10:39 AM   #1
replacing lallys
i want to replace wood lallys in basement with steel columns do i need an engineer and do i need a permit
hamilfr is offline   Reply With Quote
Old 04-18-2011, 06:56 PM   #2
Knucklez's Avatar
Rewards Points: 932
try posting over here:
Does your job require a permit?
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 04-19-2011, 10:50 AM   #3
Rewards Points: 5,336
I would think you need to know what loads the posts are now carrying so you can replace it with the correct bearing column.
I don't think you can assume that any metal post will be stronger that the wood post you now have.
Ron
Replacing water line for refrigerator seannymurrs Plumbing 13 04-09-2011 06:30 AM
Replacing Section of Feed Line When replacing kitchen faucet??? spyboy Plumbing 5 03-21-2011 02:57 PM
Homeowner needs advice re: replacing existing hardwired under cabinet lighting bombacho Electrical 4 02-27-2011 07:57 AM
Replacing Windows? Kyle Remodeling 13 12-17-2009 07:03 PM
