Replacing Lally Columns: Help! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 11:58 AM   #1
Replacing lally columns: Help!
Hi,
Recently purchased a 1926 Farmhouse outside of Boston. Had structural engineer do an assessment before I started my planned (non-structural) renovations. From his assessment, the main support beam (6x6) is solid but the house has some minor sagging. Given the old foundation, he suggested replacing the 2 existing lally columns with 3 new ones (on new footings) to reduce the spans. (House footprint is 24x24, foundation of concrete block, 1.75 story, standard platform framing, pitched roof )
So, couple of questions:
1-He mentioned footings should be 4 ft deep. Assuming the depth is due to frost line? And is this depth correct? Reason I ask is that most articles & discussions mention footings that are much more shallow.
2-From my reading, doesn't seem to have consensus if pad should be level to or above the floor line. Advantages/disadvantages to either? (I do intend to finish the basement someday, but I anticipate having to box in the lallys)
3-Same goes with a single or multi-phase footing pour. From what I've read, a multi-phase pour can help reduce any lally settlement/movement issues due to continued foundation/ground settlement. Advantages/disadvantages to either?
Thanks in advance for your advice!
Jen in MA
navi_jen is offline   Reply With Quote
Replacing Porch Columns mcwolfe6 Building & Construction 8 05-12-2010 07:51 PM
Do I need to replace my Lally columns? charbroiled Building & Construction 5 09-24-2009 09:29 AM
Replacing wood posts with Lally Posts Rugbymuffin Building & Construction 1 03-05-2009 11:14 AM
replacing front porch columns rayrgdx General DIY Discussions 4 07-23-2008 06:08 AM
Replacing a concrete tube lally Bob2468 Building & Construction 5 05-08-2007 09:27 AM
