Old 08-28-2006, 03:41 PM   #1
Replacing a Garage Sill Plate
I need to replace the sill plate by the side door of a 1 car detatched garage. Can this be done by simply cutting out the bad area and placing a new treated board in its place? Is this more involved than that? I the bad area is around the door, but I plan on cutting back about 4 feet to be sure.
stanisj1 is offline   Reply With Quote
Old 08-28-2006, 06:16 PM   #2
Home Improvement Guy
ron schenker's Avatar
What caused the sill plate to go bad, and why only in a small area?
ron schenker is offline   Reply With Quote
Old 08-29-2006, 09:21 AM   #3
I think it was years of rain water build up. There is no gutter currently on the garage, but I plan on adding one. The only place that rotted was right at the side door.
Old 08-29-2006, 05:41 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, you can cut it out and replace it. If it is a large area, do a temporary shore-up of the ceiling joists. Either way, cut the nails with a recipricating saw and dig the pieces out and replace...Just make sure that you find what the actual moisture problem is and fix it first.
- Build Well -
how to fix rotted sill plate carole2cd Building & Construction 7 03-26-2011 07:19 AM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 11:23 PM
Replacing the Sill on a Double hung Window Marshall Building & Construction 2 03-30-2007 12:18 AM
Studs to Sill Plate Tim Building & Construction 4 09-24-2006 03:23 PM
