-   -   Replacing a Garage Sill Plate (http://www.diychatroom.com/f19/replacing-garage-sill-plate-3696/)
stanisj1 08-28-2006 02:41 PM
I need to replace the sill plate by the side door of a 1 car detatched garage. Can this be done by simply cutting out the bad area and placing a new treated board in its place? Is this more involved than that? I the bad area is around the door, but I plan on cutting back about 4 feet to be sure.
ron schenker 08-28-2006 05:16 PM
What caused the sill plate to go bad, and why only in a small area?
stanisj1 08-29-2006 08:21 AM
I think it was years of rain water build up. There is no gutter currently on the garage, but I plan on adding one. The only place that rotted was right at the side door.
AtlanticWBConst. 08-29-2006 04:41 PM
Yes, you can cut it out and replace it. If it is a large area, do a temporary shore-up of the ceiling joists. Either way, cut the nails with a recipricating saw and dig the pieces out and replace...Just make sure that you find what the actual moisture problem is and fix it first.
