Replacing A Garage Door With A Wall And Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2011, 02:01 PM   #1
replacing a garage door with a wall and window
I have a garage that I would like to make an office. What is the proper way for making an exterior wall so no water leaks through?
stewart7 is offline   Reply With Quote
Old 05-13-2011, 05:26 PM   #2
Rewards Points: 5,336
If you have a standard driveway that slopes to the street, you don't have to do too much. You can frame right on the concrete. If you want insurance, lay a course of block accross the opening and frame on that.
Permits will probably be required.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
stewart7 (05-14-2011)
Old 05-13-2011, 06:59 PM   #3
Too Short? Cut it Again!
Might change your tax assessment.
Old 05-14-2011, 07:25 PM   #4
my garage is gutted right now and i have notice the framing is built on a foundation about 1 to 2 inches high. can i just fill this spot where the garage door was with cement to match the foundation? also the water runs toward the house not away
Old 05-14-2011, 09:08 PM   #5
Rewards Points: 1,016
In many areas a garage conversion requires a building permit to ensure the space is appropriate for conversion to living space - safety, proper usage, setbacks, etc. Suggest to ensure you have investigated this before moving forward with actual work.
Old 05-14-2011, 11:04 PM   #6
You need to correct the water issue or the conversion will be water logged.
Ron
Old 05-15-2011, 10:57 AM   #7
temp wall
I did almost the same thing in my home, only I put up the wall, no window, two feet in from the door. I used the two foot space for storage from the outside and didn't have to worry about any tax changes or permits. I removed the wall before selling the house and ended up with a nicely decorated garage for the new owner.
Otherbill is offline   Reply With Quote
Old 05-15-2011, 11:40 AM   #8
All Glass's Avatar
Installing The Window
Check to see if you are required to use an impact window or not. You may be able to use a regular window and apply storm shutters (this is usually the cheaper way to go). One thing you want to make sure of is that you seal all around the window with a good caulking like polyurethane or silicone depending on your substrate. Window leaks can cause a lot of trouble and they can be costly to repair. If you are going to construct your wall out of wood, use a good window wrap around the whole opening before installing your window. Good luck on your project.
All Glass is offline   Reply With Quote
Old 05-15-2011, 11:43 AM   #9
Kerry-All Pouch creator
Woodsmith's Avatar
Send a message via MSN to Woodsmith
What is the driveway surface next to the garage made of? If it's soft (like gravel or clay), you could dig a little trench and put some kind of small diameter pipe in (with holes drilled in it to catch the water) to divert any runoff. If it's asphalt, it still might be possible.
Woodsmith is offline   Reply With Quote
Old 05-15-2011, 12:08 PM   #10
Framing Contractor
Call your building department and ask them because they are the only ones who can tell you what your codes are. You will also need permits and inspections to do what you want anyway.
Where I'm from you can't just frame on top of the slab. We always install a course of block to the height of the existing block because you have to have a minimum of 6" above grade to the framing/siding. Building a wall right on top of the slab is not code or a good thing to do no matter if your driveway is pitched away or into the slab.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-15-2011, 02:01 PM   #11
Tizzer's Avatar
Rewards Points: 452
Have you given any thought about electric and/or plumbing?
Tizzer is offline   Reply With Quote
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Replacing a window in brick wall? walkman Building & Construction 4 10-08-2009 07:07 PM
Putting Window in Garage Wall palmernjp Introductions 0 09-29-2009 05:18 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Replacing a window in a foundation wall? Marlin Carpentry 14 11-04-2007 10:21 AM
