Old 02-23-2011, 01:30 PM   #1
replacing floor in mobile home aka trailer
We are looking at a trailer that has some very soft spots in the floor. Apparently the floor was made with chip board. To replace that floor must I remove all the chip board or could I lay marine grade plywood over it. That would be a much easier fix. Thanks.
beech is offline   Reply With Quote
Old 02-23-2011, 01:54 PM   #2
I've never worked on a mobile home, but I'd never leave a compromised floor in a house and cover it up.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
beech (02-23-2011)
Old 02-23-2011, 03:20 PM   #3
I used to work property maintenance in a trailer park years ago and delt with soft spots in the floors from time to time...
I cut the floor in to manageable pieces using a skill saw and then used a crowbar to pry up the sections. Then cleared all the nails/screws from the joists and laid down the new floor...I put down 3/4" plywood.
Also, I split my work space up so I could replace it in sections (half and then the other half) helps if furniture is being moved around!
Fantastic is offline   Reply With Quote
The Following User Says Thank You to Fantastic For This Useful Post:
beech (02-23-2011)
mobile home related metal roof insulation chris313scorpio Building & Construction 0 09-28-2010 10:29 AM
putting mobile home on an old house foundation rkr1991 Building & Construction 3 08-19-2010 10:20 AM
venting from mobile home through new metal roof jeanmoon Roofing 2 07-27-2010 09:39 PM
Replacing Mobile Home Package AC Unit jack roscoe HVAC 3 05-24-2010 03:13 PM
running electric under mobile home brianbrianj Electrical 6 05-09-2010 04:49 PM
