-   -   replacing floor in mobile home aka trailer (http://www.diychatroom.com/f19/replacing-floor-mobile-home-aka-trailer-96341/)
beech 02-23-2011 12:30 PM
We are looking at a trailer that has some very soft spots in the floor. Apparently the floor was made with chip board. To replace that floor must I remove all the chip board or could I lay marine grade plywood over it. That would be a much easier fix. Thanks.
Ron6519 02-23-2011 12:54 PM
I've never worked on a mobile home, but I'd never leave a compromised floor in a house and cover it up.
Ron
Fantastic 02-23-2011 02:20 PM
I used to work property maintenance in a trailer park years ago and delt with soft spots in the floors from time to time...
I cut the floor in to manageable pieces using a skill saw and then used a crowbar to pry up the sections. Then cleared all the nails/screws from the joists and laid down the new floor...I put down 3/4" plywood.
Also, I split my work space up so I could replace it in sections (half and then the other half) helps if furniture is being moved around!
