Replacing Deck Boards - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 09:21 AM   #1
Replacing deck boards
Hello all,
I am replacing all the deck boards on a 30x20 deck. I have removed half the boards already. The existing boards are rotten and soft, so when I remove them, the old screws pull right through and are left sticking straight up in all the joists. The joists are in good shape though. I have been zipping off all the old remaining screws with an angle grinder, it goes pretty quickly. My concern is, when I put the new decking boards down, I'm afraid I will be hitting many of the old broken off screws that remain in the joists.I don't want to put unneccessary holes in the new deck boards everywhere. Am I better off shooting the new boards in with ring shank nails??
lisfisher is offline   Reply With Quote
Old 04-29-2013, 09:45 AM   #2
Old School
Willie T's Avatar
Try using one of the newer angle screwing methods (Tiger Claw Clips?) and no screws will show anywhere.
http://www.deckfastener.com/pages/welcome.asp
Willie T
Old 04-29-2013, 09:56 AM   #3
Too Short? Cut it Again!
The odds of you hitting the old screws is pretty slim. If worried about it, just shift your screw or nailing pattern over an inch in either direction.
The hidden fastening systems, like those shown, are quite nice.
Old 04-29-2013, 09:58 AM   #4
Is there a significant difference in holding power with ring shank nails vs screws?
Old 04-29-2013, 10:04 AM   #5
Old School
Willie T's Avatar
I, personally, would never use nails of any kind in a deck installation. I'd imagine any type nail would eventually raise back out.
Willie T
Old 04-29-2013, 10:06 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
you will be able to manage insertion better with screws as opposed to nails and avoid board splits better as well especially with the slotted tipped popular deck screws available now. nails have a better shear value but that is about the only thing better IMO.
hand drive is offline   Reply With Quote
Old 04-29-2013, 11:02 AM   #7
I learned to build decks with nails and before nail guns (I do feel old at times) but we always put them in at an angle.
I would definitely use weatherproof deck screws now though. Or the hidden fasteners.
Dry boards? How far apart should i place my deck boards stofferb Building & Construction 3 07-09-2012 10:05 AM
Deck staining with on combination of old and new boards. vldoo Painting 5 05-25-2012 10:52 AM
Underdeck shed , can i roof w/pt plywood & put deck boards to it? BigTy General DIY Discussions 6 05-25-2011 01:45 PM
attaching pressure treated deck boards? trimdoctor Carpentry 10 04-05-2011 08:05 PM
Deciding on replacing deck or enclosing maj0819 Building & Construction 4 03-23-2011 02:43 PM
