Old 07-26-2010, 08:55 PM   #1
Replacing damaged subfloor - Help!!
While making repairs to the sill, I noticed that the subfloor itself is in pretty bad shape. What is the best way to replace subfloor? My current subfloor is made of planks. If the damage goes several feet into the room, what is the best way to replace the subfloor? Should I stay with planks or go with plywood? What about a temporary wall? I have one now but if I remove the subfloor I will need to build a taller temp wall which is no problem but then if the wall is sitting on the floor joists, how do I insert the new subfloor? Should I build several small temp walls? Any suggestions will be great.
Michelle D is offline   Reply With Quote
Old 07-30-2010, 12:47 AM   #2
Moderator
A picture would be nice...... After the temp wall is in, replace 1/2 of the flooring, add blocking at the joist bays, move the temp wall, piece in the rest nailing to the blocking.
Be safe, Gary
Clothes taking longer to dry?
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-02-2010 12:21 AM
replacing damaged eaves and adding additionaldownspout gerrym365 Roofing 4 10-30-2009 01:17 PM
Replacing flood damaged furnace/ac cebeling HVAC 1 07-08-2009 08:35 PM
replacing damaged subfloor sbeam Building & Construction 1 04-21-2009 05:00 PM
Replacing damaged BX line in kitchen wall fishnyc22 Electrical 5 02-17-2009 01:40 PM
