Replacing Closet Doors (PICS) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 03:41 PM   #1
Busy DIYer
picflight's Avatar
Rewards Points: 150
Question
Replacing closet doors (PICS)
Here is a corner of my closet, it is from a 50's home. I want to put in bypass mirror doors. The current opening is less than 78". I am wondering why this closet was built this way, off the floor. The other closets in the bedrooms are the same way.
If I remove the framing of this opening and try to lower the floor of the closet so that it is level with the floor, I am wondering what I will find inside. Is it doable without some major demolition?
picflight is offline   Reply With Quote
Old 11-08-2011, 03:55 PM   #2
kwikfishron's Avatar
Rewards Points: 996
You can certainly remove the platform and you will likely find unfinished sub floor underneath.
kwikfishron is offline   Reply With Quote
Old 11-08-2011, 04:38 PM   #3
Busy DIYer
picflight's Avatar
Rewards Points: 150
That's what I am hoping to find, I wonder though if the sub-floor inside the closet is at the same level as the room floor.
Sent from my iPhone.
Old 11-08-2011, 04:51 PM   #4
Rewards Points: 996
I would just about bet the farm on it.
Old 11-08-2011, 05:08 PM   #5
Busy DIYer
picflight's Avatar
Rewards Points: 150
Thank you for the encouragement. :-)
Old 11-08-2011, 06:29 PM   #6
Old School
Willie T's Avatar
Of course someone could have gotten lazy and run some tubing through there.
Willie T
Old 11-08-2011, 06:33 PM   #7
Rewards Points: 996
In all of the bedrooms?
But you’re right, you never know.
Old 11-08-2011, 09:11 PM   #8
Rewards Points: 502
I looks like an old house and the closets were styled after even older style wardrobes from pre-closet days.
forresth is offline   Reply With Quote
Old 11-08-2011, 11:29 PM   #9
Thadius856's Avatar
Rewards Points: 504
A friend of mine had three closets like this in an older house he purchased.
He was able to remove the buildup, repaint the newly exposed areas, and lay cedar plank flooring in each in the course of a single weekend.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Tags
closet doors
anyone ever swap out interior doors without replacing the frames? diy'er on LI Building & Construction 11 01-08-2017 07:07 PM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 05:36 PM
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 07:00 AM
Sliding mirror closet doors Liv Remodeling 1 02-17-2011 12:07 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
