Replacing Brick Window Sills - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 06:08 PM   #1
Hi everyone, first post. I'd like to know how to remove and replace the brick sills on my home. About seven because they are broken and chipped. Want to replace with what looks like concrete or stone sills very common. My problem is i've never done anything like this so any help would be appreciated.
thanks Gary
gmac111 is offline   Reply With Quote
Old 06-11-2009, 08:30 PM   #2
Have the same scenario. Item 139 on the to do list.
It was stylish but poor planning 35 years ago. Apparently it eventually allows moisture to penetrate the morter, then freeze and pop the bricks.
A neighbour had his sills replaced this spring with slabs and it looks great. His brick guy measured and ordered the slabs then did the remove and replace all in the same day. I might use my diamond grinder but I think his guy just chiseled them out and remortered
Chemist1961 is offline   Reply With Quote
Old 06-11-2009, 09:53 PM   #3
yeah chemist, I had 2 windows done the same way 2 years ago they look great . the rest of my windows are still brick sill.I lost the number of the guy who did my sills so I think I'll try it myself. If I can get some help on how to do it.
Old 06-12-2009, 09:54 AM   #4
Rewards Points: 5,336
Do you have a photo? What replacement material did you use?
Ron
replacing wooden exterior window sills jcharrison Carpentry 5 08-09-2009 11:32 AM
Replacing Brick with Wood siding HLB Carpentry 1 06-11-2009 10:17 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
