Replacing Brick Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 12:49 AM   #1
Replacing brick foundation wall
I have a brick foundation under a 3 sided bay (sized approximately 16x5 feet). The foundation is failing and needs to be replaced. It does not appear to be much of a footing under the brick. My thought is to put temporary supports under the bay, remove the foundation walls, put a proper footing in and then rebuild the wall. Does this sound doable? Any suggestions or recommendations?
bigdog54 is offline   Reply With Quote
Old 12-02-2010, 06:41 AM   #2
Rewards Points: 4,534
that's exactly how its done,,, if your ' bay ' is like ours
( breakfast room ), the dead load isn't much & built-up 2x8's cribbed properly should hold it in place even for an occasional fat granny you'd also need to spread the load to the joists, of course,,, some other stuff to consider but you're on the right path im-n-s-h-fo
brick (Need Help Replacing Door in Brick Wall) paul777 Remodeling 1 06-27-2010 06:22 AM
Replacing Brick with Wood siding HLB Carpentry 1 06-11-2009 11:17 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 03:45 PM
