Replacing 4x4 Posts On Deck - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 11:44 PM   #31
It's always something
Rewards Points: 150
Originally Posted by hand drive View Post
1/4 inch is not to bad in most cases. if you were to hold a level against many surfaces of your home you would be amazed at how out of level things are either from time and settling or from being built out of level.
Originally Posted by scottktmrider View Post
Being out of level is no big deal unless its alot.Really if it doesnt look out of level you will be fine,not like people will put a level on it when they come to your house.
You guys are right. I need to stop being such a perfectionist lol
It's always something...
SingleGuy is offline   Reply With Quote
Old 07-30-2012, 07:19 AM   #32
AHH, SPANS!!!
Rewards Points: 1,166
I just might show up with a laser and a level
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
SingleGuy (07-30-2012)
Old 07-30-2012, 08:22 PM   #33
Rewards Points: 150
Sweet. I got two posts up now:
I let my OCD get the best of me and leveled the roof line. However, even though the fit is tight, there is still a gap in one of the posts to the roof-line. I'm not worried about this since the fit was tight. I'm more worried about water getting in the gap though. What's my best option to keep the water out?
I'm considering wrapping all the 4X4s with 1/4" plywood just to finish it all out. That way I could seal it all up with caulk. It'd be a little work but might be worth it in the end. Opinions?
Old 07-30-2012, 08:34 PM   #34
Rewards Points: 150
To replace the railings, I plan to do something similar to this:
Old 07-30-2012, 08:37 PM   #35
AHH, SPANS!!!
That post is under the overhang and will not get any water if the roof does not leak. I would use glue and put a shim between the post and post plate to tighten that bearing connection more. 1/4 plywood will be wavy, maybe consider full 3/4 treated stock to wrap the posts. Something that is not to wet with treatment.. even consider cpvc lumber for the wrap
Old 08-03-2012, 01:50 PM   #36
Rewards Points: 150
I'd like to run this by you all before I commit the saw to the wood. Is this design bad? I don't love it since the rails are going to be 3.5" out from the deck ( second image.
I did that in Google Sketchup hoping to get my idea across better.
Old 08-03-2012, 02:12 PM   #37
Rewards Points: 150
After I thought about that design, the more I realize it's not safe. A kid's leg could go through that. My local codes don't seem to specify anything about that either but I'm going to check again.
Old 08-03-2012, 03:51 PM   #38
Rewards Points: 454
I know the code in my area says you should not to be able to fit a 4" ball between any spindles or under the lower 2x4.
scottktmrider is offline   Reply With Quote
Old 08-03-2012, 04:49 PM   #39
kwikfishron's Avatar
Rewards Points: 814
Why do you want to add post to the outside of what's already there???
Never seen anything quite like that before.
kwikfishron is offline   Reply With Quote
Old 08-03-2012, 10:57 PM   #40
Rewards Points: 150
I dont really want the posts that are holding up the roof to do double duty. If it's better to simply toe-screw into those existing posts with the railing, then by all means, I'll do that. Plus, my thinking is that by using seperate posts for the rails, it'll be more solid because I'll be using hex-bolts to mount those rail posts.
Old 08-04-2012, 05:46 AM   #41
Rewards Points: 814
It’s ok for the post to do “double duty” and support the railing.
I’m more concerned about the post to beam connection. Those post base aren’t designed to be a post to beam connector. Also it looks like you just used deck screws to attach the bracket to the post and the beam above it. If those are decking screws there not rated for any type of structural connection like that.
Did you at least run a ˝” lag from the bracket into the beam above?
Old 08-04-2012, 07:33 AM   #42
Rewards Points: 150
I started to run a jag but that beam is two 2x4s and the lag would just go between them. It wouldn't really bite into anything. Should I still do that? How long of a lag?
Old 08-04-2012, 08:43 AM   #43
Rewards Points: 150
I went ahead and got 3" lag screws for the top where that beam is and 2" carriage bolts for the bottom.
Thanks for replying and getting me to do that
Old 08-04-2012, 08:17 PM   #44
Chicago, IL
Michael Thomas's Avatar
For starters, in the opinion of the American Wood Council, you should not be using 4x4 posts in that manner, see page 7 here.
Even when 4x4" pastes are considered acceptable, the use of a 4x4" to support a structure above the deck is questionable, at best.
More generally, as regards the attachment of posts supporting deck guardrails, see Code-Compliant Guardrail Posts.
Bottom line: ask the AHJ that they want to see there.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
SingleGuy (08-05-2012)
Old 08-07-2012, 07:22 AM   #45
Rewards Points: 150
The original 4x4 posts held up the roof pretty well. They just warped mainly ( in my opinion ) because the wood was never treated. Stain was never applied and I don't think it was even pressure treated.
However, I finally got it done:
What should I do to fill in these slight cosmetic flaws?
I'm pretty happy with how it turned out overall considering this was my first time.
Now, on to replacing the steps!
Sandwiched beams on notched posts for deck billybarty Building & Construction 3 05-21-2011 01:19 AM
Framing deck using 6x6 posts supporting pavillion above bassprokd Carpentry 3 04-27-2011 06:28 AM
How to connect deck joists to posts? bryanf Building & Construction 10 04-13-2011 02:07 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 02:55 PM
