Replacement Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 09:50 AM   #1
replacement windows
what replacement window do you recommend? are the pella themastar good or not?
ireny18 is offline   Reply With Quote
Old 11-12-2010, 12:20 PM   #2
When you say replacement windows you do mean that the windows will be the exact same size and you are going to be using the existing casing and framing that is already there correct?
When looking at windows the main things you want to look for double or even triple paned, low e glass, argon gas and NFRC rating (the lower the better). Also decide what king you want (vinyl, wood) Vinyl would be your best bet for virtually maintenance free.
suboveryde is offline   Reply With Quote
Old 11-12-2010, 06:13 PM   #3
Do it right.
thermastar is pellas low end window, i looked at a couple of their sliding doors until I found out they didn't meet the specs for the 30% federal tax credit, decided to go with Anderson and I have no regrets.
SubSailor is offline   Reply With Quote
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 09:56 AM
Replacement Windows lucky8926 Building & Construction 36 10-13-2010 12:09 PM
Vinyl replacement windows - RBS Performance Plus? heavyharmonies Building & Construction 8 09-01-2010 04:48 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 04:33 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
