#1 |
replacement windows
thinking about vinyl pella replacement windows with lowes installlation. I need soom input on the windows and lowes work. Thanks.
#2 |
Contractor
replacement windows
I prefer Anderson but Pella is probably just as good. As far as the installation goes, Lowe's just uses any contractors that are signed up with them, so it's very difficult to say what you will get. Although, if they have problems with a contractor, they tend to not use them anymore. This is all managed locally by each store. A friend of mine used to install for Lowe's. I know he did good work, but there were others...
You could check out one of my articles on window replacement and DIY!
Regards, Ken Walker |
#3 |
replacement windows
I installed 1 pella from lowes last year and it fell apart after 6 mos. It was able to be fixed but it was more complicated than i thought a window should be. The one I had trouble with was single hung, ( up and down), and had a thin piece of cord that had a friction knot at the end. The friction knot was the problem for me but I can't imagine that cord lasting 20 years. I've also installed hundreds of Pella's in the past and found they always required a very skilled carpenter to install properly. I like a window with simple designs that can stay square and true when being shiped and handled. HS
| Display Modes | |
| soft-lite replacement windows | cambie | Building & Construction | 5 | 09-10-2007 06:58 AM |
| measuring for replacement windows. | sflamedic | Remodeling | 9 | 07-05-2007 10:05 AM |
| Opinion on HD American Craftsman replacement windows | Jims69 | Remodeling | 2 | 10-26-2006 04:02 PM |
| How do I install new windows? | RickT | Carpentry | 17 | 10-12-2006 07:06 PM |
