Replacement Window Rough-In Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 03:28 PM   #1
Rewards Points: 280
I'm planning to replace a window to provide more light into a room. Current double-pane window is 28 inches wide by 48 inches high.
I plan to increase the window size to 42 inches wide by 54 inches high.
From what I can tell at this point, the current window header is 2x10. Is 2x10 the correct size or can the window be framed with 2x8 or even 2x6?
I want to move the window up higher on the wall. To do this I will need a header smaller than 2x10.
Thanks.
Earnie is offline   Reply With Quote
Old 12-17-2011, 04:28 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,060
you will have to check with your local building authority as to what the codes are in your area. wind load and snow loads are key things when determining header dimension also key in if there are point loads coming down on the window.
in some situations where headroom is a issue i will sometimes install a flush header in the floor system. this means the header is actually sitting on top of the top plate and any joists will hang off the header as opposed to sitting on top. this has to be approved by a engineer though
woodworkbykirk is offline   Reply With Quote
Old 12-17-2011, 04:35 PM   #3
Rewards Points: 280
Ok, I guess I should have known engineering would be required. I haven't done anything yet. I was just wondering how tall of a window I could possibly install. Thanks.
Old 12-17-2011, 04:58 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
If this is a gable roof scenario, no problem going with a smaller header. If you have rafters right over the window, I would advise against a smaller header.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-17-2011, 05:08 PM   #5
Rewards Points: 280
Yes, rafter are above the current window. I'll get this looked at by an architect/engineer.
Old 12-17-2011, 05:11 PM   #6
Disabled wood vet
titanoman's Avatar
He's going to tell you that you can only go down with the window, not up. I promise.
Old 12-17-2011, 11:40 PM   #7
Rewards Points: 163
Since you are going wider, you will need to replace the header. You might be able to go smaller then a 2 x 10 but it will reguire steel or lvl's.
paul100 is offline   Reply With Quote
Old 12-18-2011, 09:02 AM   #8
Rewards Points: 280
There is 16" from the top of the window frame to the ceiling on the existing window. I have no idea how the current header is framed until I open up the wall and look.
I'm sure the header size is based upon how wide the window is and what is supported above. At this point I'm not sure the existing header is the correct size.
Is there a standard for how high a window can be from the ceiling or is it based upon the header size?
Old 12-18-2011, 09:17 AM   #9
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
Look guys, although getting an engineer out there to approve a solution might be a good idea it is not required in all situations like this.
May not be required in this situation either.
North Carolina is under the 2006 International Residential Code which has prescriptive solutions for this scenario. As long as it is for a one or two family dwelling not more than 3 stories above grade, that is.
Andy.
AndyGump is offline   Reply With Quote
Old 12-18-2011, 09:17 AM   #10
Rewards Points: 150
Keep in mind, if you get the top of it out of line with the other windows and doors, it could make the house look "funny". Most always, all exterior windows and doors are set at the same height.
guest is offline   Reply With Quote
Old 12-18-2011, 11:07 AM   #11
According to the IBC, provided that there is no floor load, with a pretty much worst case scenario of a 50lb snow load, plus the ceiling load, and a building width of 36ft, you can use a double 2x6 header for openings up to 44in. So, unless you have some huge span or extremely high loading, you should be fine with the smaller timber. Take a look at Table 2308.9.5: http://napasolanoicc.org/Links/IBCSp...apterFinal.pdf.
dave54 is offline   Reply With Quote
Old replacement window jsfoltz Windows and Doors 1 08-26-2011 08:27 PM
Install replacement window while keeping new construction window in place key1cc Windows and Doors 9 03-25-2011 09:15 AM
Window replacement Help (New Construction) gregt848 Building & Construction 3 10-18-2009 07:59 PM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 11:19 AM
latest problem...window replacement gone_fishing Remodeling 10 02-11-2008 09:24 AM
