Old 03-23-2007, 08:48 AM   #1
mt232's Avatar
Replacement window as new construction
the company that is doing the shell for my add-a-level are putting in replacement windows....there is no "nailing fin"
Is this okay? should I insist on something more? I was told that they should be able to add a nailing fin, is this so? is this neccessary?
thank you
mt232 is offline   Reply With Quote
Old 03-23-2007, 11:40 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
thank you
Is this necessary...yes it is.
Some window manufacturers make the 'fins' or nailing flanges that can be retrofitted onto their replacement windows.
Personally, we don't like the kits we have run across (Most don't create the weatherproof seal you get with New Const. windows), and we prefer only actual new construction windows for new construction installations.
That doesn't mean that the ones that are going to be used on your home are not good...it depends on the manufacturer. (FWIW - looks like someone messed up the window order somewhere along the line)...
- Build Well -
Old 03-23-2007, 12:18 PM   #3
mt232's Avatar
Thanks.
I think they seriously underpriced the job and are now trying to cheat a little. luckily i'm protected by building instectors, friends/advisors and the smart folks here.
thanks!
More On This Topic
Talk about cutting the wall, and now that it’s clean and flush and flat, it’s ready for us to put the wire on. Typically you’re going to use regular construction wire or like a chicken wire with a round pattern. I didn’t happen to... Read More »
Hi! I’m William Myers from Austin Subaru for Expert Village. Okay now I’m going to show you how to change out wiper blades, they’re pretty easy. There’s just a little clip on the bottom side you push it down, you push down on the... Read More »
Hi I'm David Belch with Thermo Guard and today on behalf of Expert Village I am here to show you how to install windows. What I want to show you now is how to measure a wood sash window. The wooden windows come with a wooden jamb frame header and sloping... Read More »
Learn How to Replace Window Squeegee Parts when cleaning exterior office windows in this window washing lesson from our professional window washer. Read More »
Wakeboarders need a reliable, durable board if they want to move into advanced skill levels. You need to know the characteristics of a good wakeboard before you make a selection. Read More »
Replacement Window vendors -recommondations? jrj Remodeling 6 07-28-2007 12:10 PM
Framing for a new construction window sandyman720 Building & Construction 2 05-31-2007 01:54 PM
Basement Window Replacement mebsdad Building & Construction 2 02-19-2007 09:10 AM
Replacement window nailing fin question gortman Building & Construction 7 11-28-2006 08:33 AM
Replacement window redline Building & Construction 3 09-10-2006 08:21 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
