Replacement Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2006, 08:00 AM   #1
Replacement window
Has anyone removed the nailing flange on a new "construction" window and installed it as a "replacement/remodel" window?
redline is offline   Reply With Quote
Old 09-10-2006, 09:40 AM   #2
General Contractor
joasis's Avatar
Many new construction windows will have a "scored line" around the nail flange, and if done carefully, the fin can be removed. When doing remodels, we generally always use new construction windows unless there is no way (brick exterior or just a single replacement) to utilize the nail flange. I like security of using the flange for attachment and sealing, but it won't work for all applications....and some may have opinions that go against how we do it.
joasis is offline   Reply With Quote
Old 09-10-2006, 07:08 PM   #3
fhi vinyl windows
fhivinylwindows's Avatar
Rewards Points: 150
Redline, I know that Pella's new construction windows can have the fins removed and installed with clips. So my answer is yes however I do not know what companies offer the clips. I would check with the window company first to see if it would cause an issue with the warranty.
fhivinylwindows is offline   Reply With Quote
Old 09-10-2006, 08:21 PM   #4
Replacement Window vendors -recommondations? jrj Remodeling 6 07-28-2007 12:10 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Replacement window as new construction mt232 Building & Construction 2 03-23-2007 12:18 PM
Basement Window Replacement mebsdad Building & Construction 2 02-19-2007 09:10 AM
Replacement window nailing fin question gortman Building & Construction 7 11-28-2006 08:33 AM
