Replacement Of Old Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-06-2006, 01:53 PM   #1
replacement of old foundation
I have a very old house. The foundation is half dirt and half finished. (the old stone)
Is it possible to put a new foundation in? What kind of cost?, will it be cheaper to move? What is all involved?
It is a dry basement, as long as I keep the down spouts aligned away from the house.
Has anyone had this done? Any views will help.
lmeyers is offline   Reply With Quote
Old 10-06-2006, 06:22 PM   #2
Rewards Points: 1,220
Anything can be done; Hell they moved a lighthouse intact! The only variables are cost and convience. Call some foundation contractors in your area, and a structural engineer, if they do not have one on staff at the foundation repair company.
Tscarborough is offline   Reply With Quote
Old 10-06-2006, 06:28 PM   #3
World famous jerk.
You can even replace a foundation a few feet at a time without any special supports or jacking often times. It's not exactly a DIY project, but I can by done if you have the patience and time to dedicate to it.
mdshunk is offline   Reply With Quote
Old 10-06-2006, 08:19 PM   #4
Without a photo it is hard to tell.
I have seen some people pour a new cement wall over top or side by side of the old wall to reinforce the old wall. Build the forms a few inches from the old wall and then pour cement (with rebar) between the old wall and the form. Let dry a few days and then remove the forms.
redline is offline   Reply With Quote
Old 10-12-2006, 12:36 PM   #5
foundation
why would you want to replace your exsisting foundation IF? there is nothing wrong with it. I have underpinned my foundation 3ft to get more ceiling hieght and did it sections at a time and sounds like the same kind of foundation I had. You would be surprised how solid it is.
wirenut is offline   Reply With Quote
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 05:35 PM
photos of foundation replacement elementx440 Building & Construction 6 04-12-2007 10:01 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
re-enforcing foundation - southern cal jhb Building & Construction 1 10-02-2006 01:15 AM
