Replace Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 10:01 PM   #1
Replace window
A leak through my bathroom window has rotted out my frame. I am going to be replacing the window and reframing. The window has an aluminum cap on the exterior. I plan on having the capping replaced after installation.
As posted on other posts it is a stucco house with no sheathing present. Is there anything I should plan prior to tackling this job? Any thing other than building a frame and inserting the window?
this will be my first window replacement.
thanks.
sharp is offline   Reply With Quote
Old 01-12-2010, 05:50 AM   #2
Not sure what you are describing. There is flashing over the outside of every window, or should be. The hard part about a complete window replacement is the exterior covering. Stucco is hard to patch properly and should be left to a pro.
how to replace old window glass to double framed glass dubaimap Building & Construction 5 06-26-2009 03:02 PM
replace broken window william farrell General DIY Discussions 3 06-07-2009 04:49 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
