Replace Treads - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 08:22 PM   #1
Replace Treads
How can I replace the treads and risers on the staircase. They seem to go under the stringers on the sides. I am not sure how to loosen this to put in a new tread and riser.
Also, the staircase is unlevel. It slopes to the right as it goes up.
Are these DIY jobs, or is this better left to a pro?
sharp is offline   Reply With Quote
Old 12-28-2009, 09:05 PM   #2
joed's Avatar
Rewards Points: 13,322
You may not be able to without removing the entire staircase. The treads and risers could be dado into the stringers.
Old 12-28-2009, 09:29 PM   #3
Any way to find out if this is the case without cutting one to see?
Old 12-28-2009, 09:34 PM   #4
Photos attached
Old 12-29-2009, 02:20 PM   #5
Drywall contractor
Rewards Points: 1,070
Or the skirt board was installed as an afterthought. Either way, you'll have to cut them to get them out...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-29-2009, 07:02 PM   #6
joed's Avatar
Can you see the under side of the treads?
Old 12-29-2009, 07:09 PM   #7
Yes, I removed the covering today to get a better look. I will send photos soon.
Also, I put up anoher post about straightening the staircase, any ideas?
Old 12-29-2009, 07:32 PM   #8
that looks like a prefab stair system which means the treads are let into the carriage. I am suprised they wrack that much if they are prefab. Check the floor at start of stairs and nosing at top for level. If they are pre fab you can clip the nails between carriage and wall on low side and if the drywall is behind the carriage you can probably jack the one side
You will probably need to remove the trim on top of carriage
Old 12-29-2009, 07:38 PM   #9
is the first tread and nosing at top out this much?
Old 12-29-2009, 08:49 PM   #10
Registered User
Rewards Points: 526
Judging by the 1910 base, skirt board and original light switch- push button, I'd think that stair wall is dropped that much. Put a level on the floor across the top floor at the stairs to see if the whole floor slopes.
Then check the pathway along the wall base from the stairs for down-stairs floor level.
Be safe, Gary
Old 12-30-2009, 06:53 AM   #11
good catch gary i agree
Replace old treads with Oak treads ruler10 Carpentry 19 07-21-2010 09:55 AM
Sanding my stairs. Wrong equipment? Question about removing treads. Kinda long, sorry Mike in Arkansas Flooring 3 04-23-2009 01:04 PM
repair or repalce stairway treads? mariad Building & Construction 4 11-03-2008 08:08 PM
Pennsylvania Bluestone Treads rjordan392 Building & Construction 4 03-30-2008 10:37 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
