Replace Taller Windows With Shorter Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 05:56 PM   #1
Replace taller windows with shorter windows
Hi, I'm planning on remodeling my kitchen. The problem right now is that it has 2 taller windows that go down to 25" from the floor. For a kitchen that's just 9x10, it's robbing any available space to put in base cabinets. I would like to replace them with shorter windows. Normally not a problem but it's an older house with asbestos siding. The plan is to build up a new sill and use a replacement window so I don't have to monkey with disturbing the siding but I don't have any ideas on how to finish up the outside to make it look half way decent. It would have to take up the space within the existing fame below the new window. I would appreciate any suggestions.
Thanks.
sleseman is offline   Reply With Quote
Old 06-03-2011, 07:42 PM   #2
Rewards Points: 5,336
Many asbestos shingles have updated versions that are not asbestos. You just need to find it. If they're not available,you should be able to modify a mineral fiber shingle to match if the surface design isn't an issue.
Ron
Old 06-03-2011, 08:00 PM   #3
Rewards Points: 276
Ron
GAF, for one, makes replacement shingles.
Jim F is offline   Reply With Quote
Old 06-03-2011, 10:49 PM   #4
Rewards Points: 150
I had the exact same problem, even including the asbestos shingles.
After considering many possibilities for years, including shortening the window, I just put a countertop across the window, attached a fake lower frame to the existing side frames on the window right above the countertop, and painted it white to match the existing frame.
The replacement window is the tilt-in kind. So the lower part of the window can be raised above the countertop and then tilted in to clean. From the inside it looks just like a shorter window. There would be a little gap between the fake frame and the window, but it is covered with a curtain.
I decided it would ruin the looks of the outside of the house to have shortened windows. Just a thought. But I'm a little crazy.
NancyNGA is offline   Reply With Quote
Old 06-04-2011, 07:07 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,212
Leave the existing exterior window frame intact, remove the existing sashes. Determine the height of the new replacement windows and frame up below that level with cripple studs. Sheath the outside and install mineral composite shingles to match existing. Insulate, drywall and install new window.
Coastal South Carolina
Old 06-04-2011, 09:29 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 380
I have seen people shorten their windows and fill in below with a raised panel or recessed panel with heavy drop molding.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
tpolk (06-04-2011)
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
Replace Windows Units with Central AC 2286743 HVAC 2 08-24-2009 06:56 PM
new windows juliejules4 HVAC 12 12-06-2006 01:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
