Replace Support Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 12:11 PM   #1
Rewards Points: 81
I have a support post in my garage that supports the I-Beam for the house. The support post is a little beat up and corroded along the concrete floor, and want to replace it. Do I need to put up a temporary support post, or can I remove the existing one and replace with a new one all at the same time?
cougar01 is offline   Reply With Quote
Old 04-08-2011, 01:02 PM   #2
Rewards Points: 1,016
You will need to provide temporary support while replacing.
Old 04-08-2011, 02:40 PM   #3
Rewards Points: 81
Thanks! Can I use a 4x4 for temporary support, or......????
Old 04-08-2011, 09:15 PM   #4
How about using an adjustable, steel jack post.
Old 04-08-2011, 10:01 PM   #5
May need a couple supports - one on either side of the existing post. The existing post may be on a footer. Your temp supports may need to have a wide base to spread the load.
____________
Vince
Old 04-16-2011, 08:13 PM   #6
Rewards Points: 81
Thanks. I am having some concrete work done on the pad outside the garage door. The contractor said that he can replace the post for me. It is still solid, but rusting along the floor from salt, etc over the years. I want to replace it before it breaks. He said that he would support the I-beam on both side of the metal post. Then he would cut the post off at the floor, fill the post that will remain below the floor with cement up to the floor level, then put in an adjustable post over top the area where the original post stood. The adjustable post, obviously, would have a top and bottom metal plate. Is this an acceptable repair method?
Old 04-16-2011, 10:23 PM   #7
Rewards Points: 5,336
If it's just surface rust or corrosion then the post would not need to be replaced.
Ron
Old 04-16-2011, 10:50 PM   #8
Rewards Points: 81
No, it's more than surface rust. It is rusting pretty deep into the post.
Old 04-17-2011, 09:49 AM   #9
This would be one of those "on site" judgement calls. The metal poles around here are filled with concrete so it adds to the support.
Ron
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
How to replace wood support posts under main beam webjanet Building & Construction 1 09-07-2008 11:15 PM
Roof support post anchors Wildie Building & Construction 8 08-28-2008 10:51 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 07:14 AM
