Replace Or Sister Saging Garage Joists - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 08:15 AM   #16
What is the secret to posting pics on this chat?
Billup is offline   Reply With Quote
Old 04-17-2010, 08:21 AM   #17
Here are some pics of my garage. If the pics you need aren't there, then tell me what area you need and I'll take a picture of it. thanks
Replace or sister saging garage joists-dsc05240.jpg   Replace or sister saging garage joists-dsc05241.jpg   Replace or sister saging garage joists-dsc05242.jpg   Replace or sister saging garage joists-dsc05243.jpg   Replace or sister saging garage joists-dsc05244.jpg
Old 04-17-2010, 08:22 AM   #18
Here's a How to
How to Post Pictures
Basically I host my pics on Photobucket & copy their link
So how to post depends upon where the pics are located
You can also attach a picture to a post
Old 04-17-2010, 08:40 AM   #19
Check my pics on page two of the last message. Thanks
Old 04-17-2010, 09:01 AM   #20
Basically I'd run LVL support perpindicular to the 2x's at the mid point
That I think is what Gary said also
So determine where that would be on each wall & let us know (pics) if there is anything on either wall that would prevent that
Old 04-18-2010, 02:58 PM   #21
Registered User
Rewards Points: 526
Those pictures are scary! I would remove the plywood and any load from above, right away. One AC wire is being pinch from the plywood above. The garage car door back-hang track is loading 50-100# on the individual ceiling joist it is hung from. I'm surprised it hasn't failed yet. To add #1 sisters next to each would require jacking the old (nearly impossible) joists and sistering. Easier would be the beam below, lifting 3/4 at a time (86#), alone . Lift one end onto a sawhorse, then ladder, then beam pocket, other end similar but onto movable double trimmer studs. OR, you could build your own beam with 2x4's and plywood, 25', 60# per ft.load, weighs 6# per foot: called "Nailed Structural Use Panel & lumber beams- Z-416, free pdf: http://www.apawood.org/level_c.cfm?c...ub_ply_libmain
Be safe, Gary
Old 04-19-2010, 01:56 AM   #22
Rewards Points: 1,092
beam support
Curious. What are you folks recommending he do for supporting the ends of this new beam? Sooner or later, it sounds like someone needs to address what is holding the beam up, and what is holding up what is holding the beam; posts and foundation below them. Or, did I miss something?
Old 04-19-2010, 09:11 PM   #23
Registered User
Rewards Points: 526
Whoops! My first two posts I said check with your B.D., forgot on this one, sorry.
He hasn't decided to sister or not, beam or not, or home-made trusses, with the approval of the Inspector for the correct wood rating, fasteners, loads, etc.: http://docs.google.com/viewer?a=v&q=...6fTirapfPwoKzA
I though we were in the idea mode, discussing options before posts, footings, sistering bolting, lateral rotation (blocking), etc., good point to keep in mind for later, though.
Be safe, Gary
Old 10-15-2015, 10:11 AM   #24
Rewards Points: 12
Dear Bill, a 25 foot span requires a minimum of 2 x 10 x X to support the structural load. Moreover, you didn't mention what the pattern is above the 2x6 that helps (forms a W" like pattern), note this helps support point load across the roof span. You will need to use bolts thru the wood to sister the joists, using nails or screws is usually not allowed in most build codes, plus don't forget the Simpson's fastners to tie into blocking at ends and where you connect to roof joists, you may use construction adhesive between exist and new joists. In addition, you will definitely want to check with a structural engineer and you're local building department on what should be the "minimum" you're going to need to do.
If it was me, I'd double check to see cost differences between LVL and no.1 structural grade wood to use. A structural engineer will be able to help tremendously on what is required and will certify install and products used.
Presently, I'm going to similar fashion but I have to sister in to existing 2x4x22 that were used in the 1920's, with no webbing support above, so I'm adding in the two by tens and 2x8 for webbing pick up the load differential across the spanin my case of only 22 feet. My problem, and you might have a similar one, is trying to get 22 feet or your case 24 or 25 feet of board into and resting the required 6" beyond walls... it's not the easiest thing to do, and I may need to cut out the rafters to get the right joists into place and then double up joists prior to putting them back.
I hope this helps, good luck
rlfranklin2 is offline   Reply With Quote
Old 10-15-2015, 11:02 AM   #25
I would pay special attention to this photo....
ron45 is offline   Reply With Quote
Garage ManCave Please Help!!! ManCaveMark Building & Construction 7 09-14-2011 03:01 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Adding ceiling joists to garage. cmj Remodeling 13 05-08-2009 08:26 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
Sister floor joists or build support wall? Bcoleman6 Building & Construction 3 02-21-2008 01:06 PM
